0.4mm HS hotend clogs
0.4mm Hardened Steel hotend clogs
Hey everyone — we’re one of those families who grabbed a Bambu A1 Combo w/ AMS Lite for Christmas and we’ve been having a blast! We’ve made a few rookie mistakes along the way, but overall it’s been awesome.
  • 0.4 SS hotend prints perfectly.
  • Swapped to 0.4 HS hotend (selected it in the A1 menu).
  • HS prints fine for 2–3 prints, then I get “Failed to extrude… clogged extruder/stuck filament” and the HS hotend is clogged when removed.
  • Swap back to SS → prints normally again (same filament/plate/settings).
Filament: Bambu PLA
Temps: nozzle ~220°C, bed ~65 (sometimes higher)
Note: I have not run flow calibration / full calibration after swapping hotends.
Questions:
  1. Does HS need different PLA temps/settings vs SS on the A1?
  2. Should I run full calibration/flow after hotend swaps?
  3. Common causes on HS (heat creep/retraction/volumetric flow) when SS is fine?
  4. Maybe my filament has moisture?
Any insight and help is much appreciated!
I’m not sure if I understood you correctly. I don’t have an A1, but with the other models, you also need a corresponding HS hot end if you change it on the printer.
