When printing in vase mode, the result is excellent.
Unfortunately, Bambu Studio does not allow setting a layer height higher than 0,56mm.
I would like to experiment with a 2,5mm line width and a 1mm layer height.
How can I set the layer height to more than 0,56mm*?
At the same time, I would like to suggest to the BambuLab engineers that, for example, with a 0,4mm nozzle you can print 1mm lines. This would be a good way to strengthen prints without losing quality.
The infill could be printed with a 0,4 nozzle using settings for a 1mm line, and the perimeter with the same 0,4 nozzle using correct 0,4mm settings.
Of course, printing with a larger line width requires reducing the speed. We cannot exceed the maximum volumetric flow of filament per second — for PLA it is 21cubic millimetres per second.
