Since taking the 2.3.0.70 update, I can not longer configure a connection to my printer. It will not give the correct options to configure it. This is the problem with needing a cloud between the software and the printer.
Just downgrade until it is fixed.
With this upgrade, I found I had to go to the Device page first in Bambo Studio to load the device, then all works correctly… An added step, but just going to that section of the Studio automatically sets the printer, then you can go back to “Prepare” and make the changes you want, slice, etc.
Thank you all for your responses. This is what it finally took to correct this problem. I had logged out of the account on both the application and the printer and the logged back in. That did not resolve the issue. I then removed the application and tried a new install of the latest version, but was still having the same issue. I then deleted the folders that contained the configuration information and again removed the application. After reinstall the application again, it finally gave me the ability to communicate with and configure the printer. An update should not require this kind of effort. At this point everything appears to be working again.
save your filament presets, delete C:\Users\User%appdata%\Roaming\BamubStudio folder alltogether, then open the app again, log in and it should work normally again. It is unbelievable, that every fkin update is like this or some other thing crashes/ does not work. Pathetic.
It seams that your solution worked for me by deleting Bambu Studio folder
