I assume, I know, first three letters, that the high flow would push more filament out making for faster printing. Is it worth it and is the quality on par, as good, not as good?
Has anyone tried aftermarket from Amazon? I noticed a few different ones out there, some with a non stick coating.
Quality is just as good as normal 0.4mm nozzles but with better layer adhesion. To make the most of the speed increase will likely require you to manually update max volumetric flow. Outside of TPU or other incompatible filament I don’t really see a reason for me to use the basic nozzles anymore
