590 hours, 7 replacement parts, 3 repair cycles… would you trust another X2D?
Hi everyone,
I’d like to hear what other X2D owners would do in my situation.
I bought my X2D in April 2 days after launch. For the first few months I used it relatively occasionally and, overall, it worked reasonably, bowden nozzle doen’t do much.
Things changed when I started a charity project to build a mobility chair for a child, funded through social media, and needed the printer to run continuously for several days.
Since then, the X2D has suffered one problem after another.
During three repair cycles, I have already replaced:
  • TH Board
  • Internal USB-C cable
  • Extruder servo motor
  • Toolhead camera
  • Left Eddy sensor
  • Right Eddy sensor
  • Extruder Connection Board
After the latest repair, I really thought it was finally fixed.
It completed a full calibration, printed with both nozzles, and completed a long print successfully.
A few hours later it developed a new intermittent nozzle temperature-control fault.
Bambu has now diagnosed another board and offered to send another replacement part.
At this point, the problem isn’t whether I can replace another board. I can.
The problem is that I’ve lost confidence in the X2D. Every time I repair it, I’m left wondering how long it will work before the next problem appears.
Bambu has told me they can replace the complete printer, but only with another X2D. I asked whether they could instead replace it with a simpler model — even a used/refurbished P1S — because right now I would rather have a reliable workhorse than a flagship full of features.
They said no.
So I’m curious:
Would you accept another X2D?
I’m not trying to bash Bambu. I genuinely want to know what other owners think.
Hang in there, at least they are trying to make it right. I’d absolutely accept a replacement.
Yes.
You don’t need to hear from another users about how happy they are or wtf else. Everyone thinks they need to chime in with that opinion lol.
But let me tell you this:
I had P1S that went through worse than your list. It was pretty much a defect on top of the defect. Everything in the printer was replaced at some point, except the heatbed, power supply, front door, and plastic panels.
It barely lasted 1k hours and then I sent it off the cliff. It wasn’t worth wasting my time on this garbage. Is it representative of all P1s and X1s in the field? No. It just a unit that was born on Friday afternoon. It does happen with Bambu and feels like it happens more often than I would want to. On the other hand, I have H2D and X2D that work much better.
So yes, it is absolutely a good idea for them to swap for another new unit. I wish they would have offered me the same swap with P1S.
I’d accept a replacement, but maybe a different data point than you’re asking – I have an X1C and no way I’m “upgrading” to these new printers.
Just too many having issues for my taste. That may be unfair and you mostly see posts from the unsatisfied users, but there have just been so many.
I’ve bought 2 at the same time. One prints perfectly from the start. Never had a failure or misprint.
The second one started acting up after a few 100 hours. Sometimes just doesn’t want to extract filament. Changed a lot of parts already, up to controller boards. BL is very cooperative, but I’ve had it with all the repairs too.
I would accept a new one.
Sometimes the manufacturing process turns out a lemon. Get the replacement.
That’s actually one of the things making this decision difficult for me.
The P1S is a much more mature platform, while the X2D is still relatively new, and I keep seeing quite a few posts about different issues with it.
I honestly don’t mind replacing parts. I actually enjoy working on the machines, so that part isn’t really the problem.
What bothers me is reliability.
I have a P1S sitting right next to the X2D that has basically been running 24/7 for the last two months. I feed it filament, it prints, and I barely think about it.
Meanwhile, with the X2D, I’ve reached the point where I’m never completely confident about what will fail next.
And strangely, in my experience with this particular unit, the failures don’t usually happen during prints. It can print perfectly fine. What I’ve noticed is that if I run the full printer calibration repeatedly — two or three times — there’s a good chance a new fault will show up.
At this point, full calibration almost feels like a stress test for my X2D. :sweat_smile:
That’s why part of me would rather exchange the X2D for two P1S and just have two proven workhorses running production. But Bambu has already told me they won’t exchange it for a different model.
So if I accept their offer, it’s another X2D.
And that’s basically the gamble I’m trying to decide on: did I simply get a bad unit, or am I trading one set of problems for another?
You got an early unit, certainly. For that reason alone I’d be interested in swapping it out. Whether they have fixed those initial reliability problems, I don’t know.
If I were in your shoes, I would accept another one. It might be the printer itself, not the entire line. It might have had some defects that are causing this issue. If it happens again with a new unit, then something is wrong.
HUH?
X1/P1 is a first generation platform that has nothing to do with being mature. You are mistaken platform maturity with ironing out issues. P1S is a unit with a well understood/documented set of issues.
P2/X2 are the second generation of the same platform. X2D is a way more mature platform, although, more complicated due to a dual nozzle design.
I think we are using the word “mature” differently.
I’m not saying the P1S is technologically more advanced or that the X2D isn’t a second-generation platform.
I mean mature as a production machine: years in the field, well-documented failure modes, huge user knowledge base, readily understood repairs, and a comparatively simple architecture.
And after having taken my X2D apart more times than I ever expected to, that difference is very noticeable.
The X2D absolutely feels like the more expensive and sophisticated machine. There are more boards, more sensors, more subsystems and considerably more complexity packed into the toolhead. Some of the connectors are tiny and delicate enough that working inside it sometimes feels more like repairing a smartphone than a 3D printer.
The second nozzle gives it capabilities the P1S simply doesn’t have, but in my actual production use it hasn’t been particularly valuable. Being Bowden-fed, I’ve already had it fail several times when using it for supports or small details.
Meanwhile the P1S next to it just keeps printing.
So perhaps “mature” wasn’t the best word. What I really mean is proven, simple and predictable.
For production, right now I would take the P1S. Fewer parts, less complexity, much more accumulated community knowledge, and ultimately I can get the same finished parts out of it.
The X2D certainly feels like it has more engineering and more value in the box. But at least from my experience so far, it feels more like an expensive enthusiast machine than the workhorse I expected it to be.
You used the word correctly,:wink: ,The P2 X2 are still in their infancy stages.
Yes, it wasn’t the best word. But that is semantics.
There are three fundamental problems with that logic.
  1. You are having a sample of one and you are building your assumptions based on that.
  2. You are comparing apples and oranges with P1S and X2D. Not sure why.
  3. It appears that you selected a wrong product for your application? If you have no value in the second nozzle, then why did you go with X2D and not P2S?
To fix these fundamental logic issues, you need to understand a few things. If you talk about complexity - compare apples to apples. In this case it’s P1S and P2S.
Dual nozzle X2D will always be more complicated and inherently will carry more fail points due to the design complexity.
When you are selecting a new machine (or replacement machine for you), what would be the benefit of carrying this accumulated knowledge? It will not save you one bit from design flaws of the first generation machine that you will be bound to experience at some point of prolonged use. Just because it’s well studied, you are still bound to experience terrible nozzle wiper, PTFE weardown, carbon rods and their horrific replacement procedure, etc. (there are many more design deficiencies, those are just the example).
And the most important … what’s the point of that discussion? You have an option between keep fixing your lemon, or getting an X2D replacement. There are no other options on the table. Stop overcomplicating for no reason.
I bought the X2D precisely for the second nozzle: two colours without wasting half a spool on poop. Unfortunately, in my experience the aux nozzle is unreliable for small details and especially tall tree supports, so that advantage hasn’t delivered what I expected.
And yes, I’m comparing apples and oranges — deliberately. I’m comparing production, not architecture.
One X2D gave me 590 hours, seven replacement parts and enough complexity that repeated full calibrations feel like a board stress test. The P1S next to it has been printing basically 24/7 for two months.
For production, two P1S give me redundancy, simpler repairs and more output than one X2D. Sometimes less is more.
So I don’t really care whether they’re apples or oranges. I’m making fruit salad.
And that’s exactly why I’m asking for other owners’ experiences: to decide whether I accept the replacement X2D, return it and buy other machines, or even give support one last chance to send the remaining parts instead of shipping the whole printer back and forth. The machine is still practically new and I’ve taken very good care of it.
That’s the point of the discussion. That’s what forums are for.
Whenever I have a “crystal ball” type of question, I have found it helpful to turn the question around a few times to look at different angles.
Starting at the back:
Will you ever be able to trust this machine?
How many more replacement part cycles are you willing to go through?
If your answer to the second question is bigger than 0, pick a number now and stick with it.
You can roll these questions into one:
What machine would you buy if you returned your current machine and got a refund?
Would you go for
  • another X2D,
  • an older single nozzle P/X series printer or
  • would you stretch to an H2D with a better track record, a direct drive on both extruders and a larger bed?
  • something else entirely?
PS: When I had to return my X1 a few years back, I benefited from the lessons learned implemented. It was over 18 months after the X1 was initially released though and a noticeable range of hardware changes occured during that time.
It is horrible what you are having to suffer. I know the feeling — you have so much work to do, but now you are getting bogged with machine failure after failure and endless repair cycles.
After having made the investment, it is probably best to just hang with Bambu Labs and let them replace your X2D printer.
The X2D was very tempting to me as it is ridiculously low priced and loaded with features for a dual nozzle printer. However, all that comes with exponential increases in complexity for its mechanics, electronics and workflow — and huge increases in mass (weight) on its printhead.
I thus decided to stick with my fleet of X1E printers since I do enormous amounts of full lifecycle work in rapid development, where a product has to go from concept to fielding in weeks — and to just observe what new users of the X2D are encountering.
Even with the X1E being the pinnacle on the X1C engineering and an absolute workhorse for printing engineering grade filaments as easily as PLA, my transition to them was not without the exact agony you are experiencing — and the root cause turned out to be something very small that the technical support (which is through the domestic vendor on the enterprise models) could never resolve.
Essentially, what was happening, was the X1E printers would each shut down, like clockwork, on achieving 850 hours of printing with PAHT-CF or PPA-CF.
The customer support was extremely responsive and would express ship to me new power switch assemblies and then new circuit board assemblies after the replacement power switches would also not resolve the problem, which would recur on the same precise milestone of 850 hours elapsed printing PAHT-CF and PPA-CF.
My entire lab looked like an X1E assembly line. With half the printers running, and the other half in various stages of disassembly for parts replacement — and my still living with the 850 hour time bomb ticking away on each X1E printer. You can imagine how stressful it was to have to redesign my lab workflow for production around the cascading 850 hour mean time between repairs metric.
I finally had to take the problem resolution into my own hands and deep dive into the electronics myself with testing gear. I pinpointed that it had to be a failure in the circuit elements of the power switch itself after exposure to the high, 60 deg F chamber heat needed for printing the carbon fiber reinforced polyamides.
Having gone through 40 of the ones supplied by Bambu Lab and receiving agreement that the vendor would accept returns on the X1E equipment for replacement with new units, I ordered new power switch assemblies from Amazon from a maker I knew had a proven track record for designing them for reliability in high temperature environments.
These things were very affordable too. I bought 50 of them for only about a dollar each.
Lo and behold these permanently resolved the mysterious X1E shutdowns.
Can you believe it was a $1 part that was the Achilles’ heel of the vaunted X1E all this time? I suspect you will discover something similar to your challenges with your H2D.
Now, here’s the thing I wanted to look out for on the H2Ds that work reliably — what losses in agility / print speed are realized with its massive print head?
I had a colleague that acquired the enterprise edition of the H2D and we did a runoff using my favorite “benchy” which is not the iconic “tugboat” but a model I designed of a condom (195 mm tall) to the exact industry average dimensions, but to be printed with 0.4mm walls and foaming TPU. One to be printed on the X1E and one to be printed on the H2D Pro, and then compared — for flawless walls (no blobs or zits) and overhangs, ability to be rolled up like a real condom and without breaking or tearing, and passing the water test of being inverted, filled with water, and looking at leaks through the walls.
Guess which printer pulled it off and which did not? The X1E sailed right through the condom benchy and passed every post test. The condom benchy printed on the H2D Pro failed on every post test.
There are things that the X1E with its light and agile print head and carbon fiber guide rods can achieve, requiring speed with finesse with extremely sensitive printing materials, that the H2D simply cannot achieve with its much heavier print head and rail system.
Thanks everyone for the replies. Some of them genuinely helped me make the decision.
At the moment I have three different Bambu models: a P1S, which is basically my production workhorse; the X2D, which has been having problems since August 22; and an A1 that I actually had brand new in the box intending to sell. I’m not a huge fan of the bed-slinger concept, but I had to put it to work to keep my project moving. I’ll probably sell it later.
I wouldn’t really call this a farm yet. I don’t even have a commercial product. I just need reliable machines to get the work done.
Bambu wanted to continue sending more parts for the X2D, but I eventually refused because it had become a cycle: replace parts > calibrate > new failure. The new failure is usually in a different component, and so far I haven’t been able to identify a common root cause.
Something else that made me less enthusiastic about continuing the repair cycle is that the replacement boards I’ve received don’t appear to be newer revisions. Judging from the markings/serials, some actually seem to predate the parts originally installed in my machine.
I asked Bambu whether, instead of replacing the X2D with another X2D, they would consider exchanging it for two refurbished P1S units. They could even keep the difference in value. But their position was X2D for X2D only.
So, after reading the experiences here, I decided to accept the replacement with a new X2D.
Interestingly, as soon as I accepted, I received a message saying they are going to discuss the case internally. I wasn’t expecting that, so let’s see what comes from it.
Thanks again to everyone who shared their experience. I’ll update the thread with what happens and how the replacement performs.
First we still have one small problem to solve: I don’t even have the original box anymore
Yes, I have an H2D that gave me issues within 2 weeks accepted a replacement, and it is fantastic. I can only say that sometimes you get a lemon, and it is time to start over, but never quit trying.
I hope it works out for you and the new machine is great!
Well, I donated my X2D and replaced it with a H2D.
That being said, I had few problems with the X2D and no problems with the H2D to date.
