95A TPU + AMS HT + 4into1 + TPU Feed Assist
Good day!
Ok hear me out, TPU95A + AMS HT, it works with the powered automatic feeder, but, with some caviats.
I spend 80% of my time printing TPU in various shore hardness, been doing that for almost a decade. The H2D is the dual nozzle, total game changer, and I started drooling over the idea of multicolor TPU prints when I started speculating on the AMS systems, and TPU for AMS. Drooling when I started to think, we can go further. My creative vision for my product line has always had multi color tpu, because of my market, and the durability.
The catch is that TPU for AMS is limited for colors, so I’m always wanted to use my vetted brands. My highest TPU color count is 6 in one print, 4 of which were TPU for AMS, with the 5th, a 95A on the right nozzle. In my experiments, I always wanted to get my color pallet in 95A to work with more then just one roll at a time. With the usual constraints, TPU95A through the bypass, directly to the right nozzle, TPU for AMS on the left nozzle. But we can go so much further.
I have spent too much time, minmaxing the filament path for the least resistance possible, and given where I came from struggling to print TPU in bowden on my old Bowden delta printers, to where we are now, the physics is pretty consistent, and we are so close to having the hardware configuration to have AMS TPU 95A.
Trying to push a flexible spaghetti through a narrow tube is going to have all sorts of friction hangups. One of the reasons you skip the normal inputs on the H2D (the filament buffer) is that its too long of a path, and the filament buffer adds a ton of friction. If you ever get curious about for much resistance your filament path has, just manually push some filament through without an AMS.
So in minmaxing that, my entire printer racking +AMS placement is positioned for the straightest, shortest, smoothest path possible. I’ve gotten TPU95A to work in both the AMS2 and AMS HT but, the AMS2 struggles. the AMS HT is a much simpler path. I have to tell the printer that I loaded a TPU for AMS roll into it to “trick” it, but the HT box will push 95A through an optimized, low resistance path. I did notice that I had to choose my rolls of 95A, only the nicest of windings will work, and I found that the AMS HT will struggle on the end 1/4 of the roll, but it DOES DO IT. In fact, the only reason I have “filament path obstructed” errors is that the AMS HT is just spinning too fast to load the 95A TPU vs the amount of resistance it faces, mostly at the end of the roll, and theres no way to slow it down. When printing TPU in a bowden setup, you cant really go fast, so this should be no different. I have a feeling that just allowing a speed change on the AMS HT loading would fix the issue. I’ve built large models on 20 hour prints in pure TPU, 95A on the right from the auto loader AMS HT, and TPU for AMS on the left nozzle using the AMS2.
Lets go one step further.
If the TPU feed assist module is meant to help an external spool of TPU feed into the extruder, couldn’t you chain an AMS HT with a feed assist module? there may be a different hardware configuration to match the speeds to each other a bit better, but if that exists in that form? why not a mod to give the AMS HT that little extra push to help overcome the “bowden” tube. Currently the TPU assist module does not support the automatic feeding of TPU without using the bypass on the back. But given that I’ve gotten this far already, just a few tweaks in firmware could take it the rest of the way. There is likely a stepper vs speed mismatch with the two pieces of hardware, but it may be moot anyway if the AMS HT can load better with just a change in speed.
And one step further, if you had more then one AMS HT feeding into a 4into 1, you could hypothetically have multicolor TPU into the right nozzle from 2+ 95A sources.
My 4 into 1 just arrived in the mail, and I have 2 AMS HT, so my experiments shall continue using 95A.
Fingers crossed that one day, an easier path to multicolor TPU can happen.
Unfortunately no, it couldn’t.
Couple theory of operation things.
The AMS, 2 Pro, and HT all operate in closed loop mode and use the buffer as the control signal that tells them when to push more filament to the extruder. They use 6-pin cables to carry both signal and power between the printer, buffer, and AMS.
The TPU Assist also operates in closed loop mode, but instead of using a separate buffer the outlet PTFE connector is mounted on a switch that is tripped when sufficient pressure exists in the tube, indicating filament has been fed all the way to the extruder. Unlike the AMS units, the TPU assist uses a 4-pin cable that only provides power, meaning there is no provision for signal to be carried back from the assist module. This arrangement works because the assist is meant to be a relatively short distance to the extruder - it would be less reliable in a longer PTFE run, or one with multiple connections.
Now, in printers that have an external buffer, that could be resolved with an arrangement that goes AMS ->Buffer->TPU Assist->Extruder, but even then there would need to be a way for the TPU assist to recognize a filament is being fed to it, which it doesn’t currently have. It would need something like an inlet filament detector. There is still an issue whete it needs to know when to rewind, I don’t know if there’s a simple path to achieving that.
For the H2 series printers, this is harder to do because the buffers are internal - a feed assist would need to be placed after the buffers somehow, plus have all the control limitations sorted out.
I’ve been looking into the Mellow LLL Plus capabilities to see if there’s a reasonable pathway to adding these inline as self contained boosters, they actually do have switches on the inlet and a self contained buffer, and are very programmable, so there may be a good path there. I have one built up in the TPU tamer configuration, located here:
…but haven’t started testing anything on it yet. I suspect it may actually be reactive enough that it could sense a filament entering it, kick in the feed motor, and then self regulate well enough that the stock Bambu buffer wouldn’t even notice something was different.
Also - on my X1C I did play around with optimizing the stock feed system to be able to handle TPU 90 + 95 natively, I modified the filament sensor in the extruder, added a tube guide going into the extruder, and made some changes to the AMS to allow it to feed TPU more easily, and did have some success there.
On the H2 series I’ve found that the buffer introduces a very significant amount of drag on the filament, so that’s one area of opportunity that may reduce the feed issues you’ve seen.
Open to collaborating further on this if you’re interested.
ooo, ok. Thank you for the explanation on the 2 way feedback. That explains a lot, as I routed my AMS HT sans filament buffer, it would load through the bypass, and almost “crash” the end of the filament at the hotend side, there was no feedback from the filament buffer, and just sent it till it reached to hotend full speed. I’ve had to replace my buffer once, and did not expect so many wires to be attached to it, but now that all makes sense.
It would require quite the tuning. the motors would have to match the feedrates pretty closely so neither motor is being pulled or pushed on in excess.
I am open to collabing on this, my first 4 printers were built from kits, so navigating some under the hood work is not a new thing, .gcoding , just a lil rusty. I’ve been spoiled with the Bambu platform since switching over on the 2 series, it just works. I haven’t had to do any tinkering like I had to on the kitbuilt deltas. Just minor things and maintenance.
I’ve been wanting to build a lid riser for a while, and replace the glass with a lasercut acrylic sheet for some increased utility. looks like the profile of the TPU tamer is low enough that if a 25-50mm riser was added. bolt it to the underside right after the filament buffer. Technically, only 1 would be needed to serve the right nozzle. I also wonder if there is something that can be done to the filament buffer itself to reduce drag, I have my old one kicking around that I can poke at
