Heyo all, i´ve been trying to get my A1 to print with an 0.2 nozzle without issues for a while now, im at my third nozzle (the first two broke down from use and scrapping) and i started to see near the second nozzle last prints that it was sometimes scrapping at the bed.
At first i thought i had toe manually change the Z-offset, so i did, i noticed that i had to use a whopping 0.20 Z offset to get that nozzle to print, any other value and it either blobbed up or started scrapping against the prints/bed. That solution only lasted for a few weeks until it finally stopped working and if i went any higher on the Z-Offset the prints started to come out wrong (you could see the lines even on 0.06 quality).
So anyway i got a third one and decided to do things right this time, a store owner from where i buy filament told me that some A1s came with an issue that made 0.2 nozzles too close to the bed and that caused them to start wearing too fast. This time then i decided to check all the screws from the hotend (yes, the three black ones from the front and the 4 small ones from behind the nozzle) and started making prints at 0.18 Z just in case.
The results where…ok i guess, while most supportless prints came out great, the brim was…wispy? You could see the strands of filament when you took it out, but overall it seem OK. The problem started when i started making Miniatures with supports and oh my, it was blobs galore from that point forward. Almost lost another hotend assembly from a blob of death.
So anyway i kept tinkering until i saw…one print that had BOTH the issues of a low Z-offset value and a high one, meaning the first layer either got scrapped off the bed OR was weak and looked like it didnt bond correctly. At this point i really just gave up, how in the seven hells can i get BOTH problems back to back with the same Z-offset? Any ideas what can possibly be the problem?
Just in case:
Bed Temp: Textured PEI 65
Nozzle Temp: 220
Retraction: 0.4
Filament: Creality Hyper PLA (worked almost better than Bambu PLA)
Cleaned the bed, the gears, checked all screws.
Did a factory reset, checked all the screws just to be sure and recalibrated everything again.
EDIT: After some more tinkering, i stood besides the printer while it started, and i could see that the parts of the brim that where semi-transparent happened to be where the nozzle sounded like it was way to close to the bed and the extruder gear clicked, some pics for reference:
Right at the red marker i could hear the nozzle scrapping the bed, i wanted to upload a video but i cant upload mp4, but i have this pic of the model, right at the feet, when the nozzle does the either the outher or inner walls, you can actually hear it almost like its scratching the print, and it only happens at those parts and with every 0.2 nozzle i used, never with the 0.4
