A1 0.8 nozzle buildup in vase mode, PLA Matte, 2 mm wall: blobs on print
I print vases in spiral vase mode with a 2.0 mm wall (a single line, 250% of the nozzle diameter) and a 0.3 mm layer height. During the print, plastic builds up on the side of the nozzle, grows with every revolution and eventually drops onto the wall. This leaves blobs and marks on the part, and it is the main defect on these vases. The vases are 180 x 250 mm and have fluted walls.
The buildup varies by color: white holds up better, while black and navy blue drop the buildup onto the part. A second A1, identical to mine and printing the same type of filament, has even more blemishes, on every print.
My hypothesis is that the line is too wide for the nozzle. As I understand it, the max line width that fits under the flat face of the nozzle is roughly the flat face plus the layer height. I have seen reports of a ~1.4 mm flat face on the 0.8 nozzle, and of an even narrower tip on the A1. With a 0.3 mm layer, that puts the ceiling around 1.7 mm, and my 2.0 mm wall exceeds it. The excess seems to climb up the side of the nozzle, and vase mode has no retraction or wipe to clear it.
Flow rate does not seem to be the issue: 2.0 x 0.3 x 20 mm/s = 12 mm³/s, well under the 22 mm³/s max volumetric speed of the profile.
What I already tried:
  • New hotend: same buildup as the old one.
  • 1.2 mm wall, 210 °C, fan at 100%: less buildup, but the wall was too thin for the product.
  • Changing temperature and fan: it only slows the buildup down.
  • Non-matte PLA: less buildup, but not zero.
Printer model used
Bambu Lab A1 with AMS lite, 0.8 mm nozzle [fill in: stock Bambu nozzle? hours of use?].
Slicer settings used
Bambu Studio 02.06.00.51, process profile “0.32mm Optimal @BBL A1 0.8 nozzle” (edited).
  • Spiral vase mode: on (smooth on)
  • Outer wall line width: 2.0 mm
  • Layer height: 0.3 mm (first layer 0.4 mm) [confirm in Studio]
  • Wall loops: 1, bottom shell layers: 3, top shell layers: 0, infill: 0%
  • Outer wall speed: 20 mm/s
  • Nozzle temperature: 220 °C (profile range 190–240 °C)
  • Max volumetric speed: 22 mm³/s
  • Fan: min 60%, max 80%
  • Bed: Textured PEI, 65 °C
Type of filament used
Elegoo PLA Matte Dried before printing in a Creality filament dryer
Any potentially useful information
Two identical A1 printers with the same type of filament give different results, with the second one worse.
What I plan to test next:
  1. Higher layer height (0.52–0.56 mm) keeping the line width, with reduced speed to keep the flow rate.
  2. Two lines of ~1.0 mm instead of one 2.0 mm line (two walls outside vase mode, or the slit trick), with the seam hidden in a flute.
  3. A coated 0.8 hotend (Micro-Swiss CHT) as an A/B test.
Questions
  1. Does anyone print vases with a 2 mm or thicker wall on a 0.8 nozzle in vase mode without buildup? With what settings?
  2. Has anyone measured the flat face of the A1’s 0.8 nozzle?
  3. Does the slit trick work in Bambu Studio, or does the gap stay visible?
  4. Is there a brand or color of PLA Matte that builds up less under these conditions?
  5. Which variables should I compare first between two identical printers?
How dry is your filament, and how do you make sure it’s dry?
I dry the filament in a Creality filament dryer, using its PLA mode at 50 °C, for 6-8 hours. Then I take the spool out of the dryer and print from the AMS lite. The whole vase takes 4-8 hours to complete, depends wich one is it
  1. That’s not long enough to ensure a dry spool.
  2. Being on an AMS lite for 4-8 hours will very likely more than wipe out your drying efforts.
You were right, thank you! I kept the spool in the dryer and printed straight from it while it was drying. I tested it on 4 different vases and none of them had the blobs.
Fantastic news! Happy printing!
