Detailed description of the problem
Printer model used
Slicer settings used
Type of filament used
Photos that clearly show the problem
.3mf file (if the file can be shared)
Any potentially useful
information that is related to the problem
Recently whenever printing on my A1 printer which I have used for about a year (1739 print hours) with no issues every print has been failing because the nozzle is too close to the bed. The problem started when i was printing a model of playing cards that was very thin so i assumed there was just issues because of that but eventually it continued getting worse and i could no longer print other things in decent quality. I first discovered that I could fix the issue by gently applying light force onto the x axis rail because it had a bit of compliance. Is this compliance regular or is there some screws i could tighten to fix the issue. I was able to figure out a workaround to my issue by downloading orca slicer and adding a z offset of 0.095mm but the app and bambu ecosystem have many QoL features I would like back.
