A1 Bridge Settings
I think Bambu’s default bridge settings are awful, I have tried to tweak them with no luck. Today I have printed a UFO suspended by bridges and it came out fantastic. What I spotted is the model when sliced, Bambu Studio didn’t detect the lines as bridges.
How can I change Bridge settings to match this model?
Thanks :slight_smile:
If you go in the sliced view you will see that most of these lines are ‘overhang wall’, so its the setting ‘over 100% wall [not bridge]’ but its set by default to the same speed as bridge: 50mm/s
A few of the bottom most lines are considered walls so there is also that oddity.
Use the ‘speed’ view in the Preview window to get a view of the speeds that are being used and working for you.
Cooling affects bridging quite a bit but this UFO will test that from just about every direction so if the UFO gives good results I would expect good results from other bridges using the same filament and settings.
Thank you, will give that a try.
Yeah the print came out super clean, I was genuinely surprised.
