I need help with my A1 printer. I haven’t been able to successfully print anything with my Bambu A1 printer that I bought in 2023 and it is due to a clicking in the extruder. I believe it’s attempting to feed the filament but for some reason it’s unable to do so, and if I do a test print, then the filament line skips whenever it clicks.
I have checked for clogs, but the filament still feeds to a degree.
I have removed the tool head cap and nozzle and tested the filament feed through the extruder, and there’s no clicking or issues there.
I bought a new 0.4 hardened steel nozzle just to make sure it wasn’t that and still it clicks as soon as I try printing with it assembled.
The maintenance settings are set to the new printer head since I was using a stainless steel nozzle and decided to purchase a hardened steel one when the clicking first began with the stainless steel one.
It feeds for a couple of seconds then clicks, feeds then clicks.
I don’t believe there is any filament in the gears because, without the nozzle head, there is no clicking or problem with the traction or anything noticeable.
I use Bambu filament, nozzles, build plates, everything. I haven’t manually altered anything within the printer settings aside from changing the nozzle head settings when appropriate.
So, it’s clicking -and backdriving-? No filament actually coming out of the nozzle during the clicking and backdriving?
Check those screws on the back of the hotend heating assembly to make sure it stays aligned + is able to level. If its REALLY untight the filament wont even enter the mouth of this part, gets stuck on the rim. If its just a little untight, it will make your printer level so close to the bed its scraping, and that can make the first layer click and backdrive - trying to push mroe plastic than is physically able to fit in that space
Okay, so I followed the instructions on disassembling the extruder and tightening the screws behind the hotend.
There was nothing within the extruder… The screws were tight behind the heater… And I thought maybe magic would happen anyway, so I decided to put it back together and test print a Hueforge bookmark I’ve designed.
The clicking continues.
Extruding was never a problem, it does that, no clog, but a consistent stream is something else. The clicking is causing skips, the rotating wheel doesn’t turn smoothly, and it’s not allowing for a smooth application of the layer. Gaps everywhere. It’s not just the initial layer, it’s all throughout the printing process, about every 10 seconds or less. I even got new PTFE tubing and hoped maybe there was some kind of friction element to it or just something else I could control, but alas, it did not improve.
When I do flow calibration on the print it made a lot more “clicking”, probably due to the amount of filament fed into the extruder.
I don’t know what is going on and I am completely lost.
I ordered the new spare part from Bambu and followed the guide to replacing it. Afterwards I loaded a filament and it extruded but then there was a couple subtle clicks during the process. I did a flow dynamics calibration again and the clicking was constant and I don’t know what it is.
Is it the AMS? Is it something else I can’t see? Some setting, some mechanical failure not found within the extruder?
Adding a different data point here, since my situation seems slightly different from what’s been described so far.
I have a Bambu Lab A2L, purchased on September 9. It’s making the same clicking noise from the extruder, but with no signs of clogging and no print quality issues at all — prints are coming out clean, with consistent flow and no skips or gaps.
The extruder wheel itself spins smoothly with no stuttering. The clicking is constant and, interestingly, starts even before the print itself begins — during the purge step where the printer flushes filament from the hotend.
I already went through the standard troubleshooting: removed the hotend and confirmed the 4 screws behind it are properly tight, as suggested earlier in this thread. That didn’t change anything.
Has anyone else run into a clicking noise that happens without any print quality degradation? Trying to figure out if this is something mechanical that’s still within normal tolerances, or a sign of something that will get worse over time.
Having the same exact problem. I also replaced the whole extruder assembly. Put all back together…same problem. I seems to happen worse on the first layer. Pulling my hair out.
