A1 mini calibration failed, nozzle temp 0 degrees
Hi, need help with my A1 mini. Calibration fails and the nozzle temp reads 0, (I think that is why calibration fails.) Also should mention it will not print because it does not know the nozzle temp.
I have noticed I can heat the nozzle manually but the display still reads 0. If I disconnect the USB cable and re-connect the temp will read correctly and the small fan on the side will turn on to cool the nozzle. The temp will not update unless I disconnect/connect the USB. I have re-seated all the plugs on the TH board.
Any ideas as to why the temp does not update?
I haven’t dealt with this issue on my A1 mini, but it sounds like your thermistor (temperature sensor) could be faulty. The thermistor is located in the hot end and that part can be replaced.
This is a guide that bambulabs has released that lists “The heater or thermistor is not working anymore” as a reason to replace and they sell the part on their site. Hotend Heating Assembly Replacement Guide - A1 mini | Bambu Lab Wiki
Maybe open a ticket with Bambu to see if they can offer some guidance as well since you’ve tried quite a bit already.
Thanks for the input.
It would be nice to test and verify if it is working correctly or not. Is there a way to test the thermistor? Like a resistance it should show at room temp? or other known temp?
I have opened a ticket btw.
you could also try a freshly formatted sd card , recreate the issue and auto upload a log file via bambu handy
Just an FYI, The TH board was the culprit.
Hopefully this will help someone one day. Thanks for the input
Hello I have the same issue, please can you tell what exactly you did? because for me doesn’t work anything :frowning: Thank you
I replaced the TH board. The nozzle temperature would read 0C, not much you can do other than open a ticket with Bambu.
Hey there,
Did they send you a brand new one or do you have to send your old one back I’m getting the same errors as well as not being able to calibrate, no z-axis home and bad nozzle temp. Any fixes or do you just have to get a brand new part
Cheers,
Zac
(i have done all the same attempts at fixing it as you)
They sent a new board and a new hot end heating assy., I did not have to send the old parts back. I did replace both parts but was able to verify the TH board failed.
One thing you can try if you really need/want to print is to power down and unplug for a day then power up and observe the nozzle temp to see if it matches the bed temp. Try to increase the nozzle temp in settings.
I was able to do a print before it failed again.
I had the same problem and have to change the TH Board too…
Mine JUST started this. I had replaced the heater/hot end and the nozzle and it refused to perform the z axis properly. Now, yep, the calibration (which worked fine multiple times this past week) comes up as ‘failed’. I’ll recheck the plugs and then hit up bambu…I have a little over a 1000 hours on this Mini. Wish me luck :wink:
