A1 Power OFF itself
Im having the exact same problem how did they come to the conclusion its the power swiutch?? Mine shuts off no power sometimes in the middle of a print but if you gently push the power switch in while still in on position it will power back up.
I made a video that was quite long enough, from the start of a print, to show the initialising process part, then the print, unitil I had the shutdown of my printer.
I didn’t stoped the video at that time, to show that te only way I had to “wake-up” the printer was to turn the switch on the back Off, then On again, and that was the exact timed screen they sent me back to say me that first of all, it needed a power switch replacement before investigating further.
Maybe something was a bit loose in this switch.
So they sent me the power switch, I replaced it, folowing the tutorial, and since, my printer didn’t have this issue again. I hope this power switch replacement will work for very long time.
I also use the replacement tuto , to look at the componants of the power card if there was noting that have melted, inflated or having some burn traces. All was good.
Hope your printer is still under waranty, so you could have a free power switch.
