A1 Print head keeps moving to clean position during printing
During recent prints the printer head moves across to the filament cleaner and clicks it then resumes printing. The frequency is approximately 8 seconds of printing then move to clean head, clicks the mechanism then restarts another 8 seconds of the print.!! This can’t be right can it??
Sounds like you selected timelapse and it will park head to take a picture at regular interval, deselect timelapse and head should not stop printing.
Hey So I am having a issue with my A1 mini where is starts the print prints for about an hour then cuts the filament a says to check if it is caught or stuck. I have resliced it four times and same problem.
I use Hatchbox PLA and am trying to print one piece in one color. Any solutions??
Thanks for the suggestion but I am aware of that option but I have disabled the Timelapse and all other printing “safety” options too…but it still does it. It has happened recently and I am thinking maybe it’s the print files that I have tried. Can’t see what else to try…
Philch, …sorry, my apologies, somehow (user error) the camera setting was still on Timelapse…!! I thought it was turned off on the printer controller but when I looked at the sd card it was recording time lapses. So thank you for your solution… it made me check again…lol.
On reflection I probably tried to change the settings while I was printing and therefore they didn’t take effect?? Even though they appeared to have been changed and probably reverted back after the print ended. That’s seems the most likely answer.
