A1 randomly pauses when printing after firmware update
Recently I saw there was a firmware update for my A1, so of course I decided to proceed with the update. Today I tried printing something and a bit after it started the print paused from “user input”, but I never paused it or did anything to it. Is this an issue with the firmware update or perhaps some other issue?
The current firmware version is 01.06 which is the latest, and the AMS Lite is also on the latest firmware version too. Is it possible to fix this in any other way instead of downgrading firmware?
“pause for user input” is specifically a gcode instruction
This happens, for example, if you command bambustudio to “pause at layer 200” so you can insert a magnet or something.
Were you printing your own file or someone elses? Check in the slicer preview to see if pauses are embedded into it.
I was printing someone else’s file, but it was kinda strange since in the instructions it didn’t specify about inserting anything else or why it was pausing it just worked perfectly. No one in the comments mentioned such behavior, so I am not sure.
will revert to 1.04, you won’t lose anything…
Mine came like this. It pauses with no error message and no pause in the slicer. Happened two times only for 20-30 prints. not too often
