I just got my A1 and am having this issue 1 week in. Has bambulab pushed a fix yet? Are others still experiencing, should I just make a habit of lowering my Z before I send a print right now?
It’s normal, it’s just a safety mechanism.
Imagine if for whatever reason your nozzle was touching the build plate, and then the print head moves, your plate would be scratched and damaged, by lifting the z up, it prevents any possible collisions.
It makes a loud noise when it hits the top of the z as there is no physical switches to detect it’s at the top, so it uses the motor to tell it’s at the top when there is lots of step losses.
I fixed it with a small modification. It’s tested and works with A1.
Change this:
;=====avoid end stop =================
G91
G380 S2 Z40 F1200
G380 S3 Z-15 F1200
G90
To this:
G91
M17 Z0.3 ; lower the z-motor current
G380 S3 Z-5 F600 ; avoid hitting top z and noise
G90
That change removes the 40mm up movement that hits the top crossbar.
Also lowers the motor current and feedrate for safe movements at this point.
I noticed that if I not move a little down the Z-axis, it will hit the top when homing the Z-axis, so to be safe i move the Z-axis just 5mm down.
Normally you will not hit the bed because when a print finishes, the z-axis is moved up more than 5mm.
Avoid moving down the Z-axis manually when the motors are off ![]()
Hope it helps
This is happening to me too, and because I have a top mounted AMS lite the cables at the top of the toolhead hit it when it goes too high with a grinding sound. Manually lowering the toolhead and then restarting the print always fixes the issue, but it’s made me a bit paranoid about starting a print.
I have seen/heard the same issue with my Bambu A1, but its not actually the Z-axis movement.
it is the Extruder Backing out before the filament has been cut,
I have specifically seen it when I have had to cancel a Print and then reprint.
Same here but in a different scenario. I’ve stopped a print in the preparing phase. When initiating a new print. The head struck the upper stops… Scary scary noises and behavior! Only a restart worked to manually tap down on the Z axis. Hope nothing is hurt after this.
The issue is still there after one year ! My A1 hits the top at the beginning of next print… Not good and easy to correct in gcode, very annoying this issue…
I just had this happen, I tried homing the printer after a tall print, that’s crazy, still no fix from bambulab
is the community gcode still updated and working?
Hi, I suffered the same problem, the extruder was high on z axis and i pressed home button which, made it ram into the upper limit of frame is your printer working nicely, did it suffered any damage?
It still prints fine but I started hearing this noise, check if you have it too: https://www.reddit.com/r/BambuLab/s/tOKOsCRZpC
It is working fine without any noise.
I was printing tall models before and never had this issue until yesterday. It goes to the top at the end of the print and when I start a new one it pops off the z axis cover and goes down… A1 mini that is..
not sure why all of a sudden it started doing it now.. I did the maintenance/calibration, but still happens so I have to manually lower it down before next print. Weird..
This has happened to me twice on my 3-day-old printer. Both times, it happened during bed leveling. The Z-axis moves up with a terrible grinding noise. When I stop the print, the Z-axis moves down and hits the bed with the same awful noise.
When I try to move the Z-axis up manually, I get an error saying there’s a problem and that I should home the printer. After homing, everything seems to work fine on the next try.
I had printed a Benchy before this happened. There’s actually a sign that it’s about to happen: if the Z-axis moves past the 50% mark, this issue occurs.
Next time, I’ll probably just hit the power button, because pressing Stop doesn’t prevent it from hitting both the top and the bottom.
