Section dedicated to the Bambu Lab P1P and anything related to it.
manual bed leveling gcode from website is not working for p1p can help me ?
How come I ca not post a new subject/question?
What do I need to do in order to post a new topic?
Hello all, after a heavy series of printing, I had my first issue. Seems it cloughted and kept printing creating thus massive rock stuck on everything. Any tips to removed without damaging? Or what caused it?
Hello,
the “P1P Enclosure Kit” is still not available to be ordered, up today it’s quite and year that I’m try to order it.
If I try the buy each single parts that compose the kit, they are available, ofcorse the total price is in this case will be €283,85 EUR instead of €170,19 EUR of the kit.
There will be the possibility to order the kit in the nearest future, or at the and the only solution will e to order each single parts?
Due to the fact that the single parts are available, another good way could be to directly apply the 40% discount of a cart that contains all of them.
thanks,
Hi
My Bambu Lab P1P don’t tell me when it round out of filament.?
Can someone help…?
Lars
HELP i need the origninal SD card that came with the P1P
dave
I have had the same problem, but from the day I tried to change my nozzle into the 6mm I can not get the board to even come close to the nozzle. I can not factory restart everything in hope for it starts working, there is nothing I have done that has worked for me until now. I can see that you too has ttied to put the glu on the board in hope that it helps, but I can tell you it wont. This printer is very very expensive and I have lend money to buy it, and now this…
It could be that the hot end is worn, or that no glue was used on the base plate
Hi there Dave I’m afraid there is no resolution to this issue as Bambu lab does not currently sell the SD card you will unfortunately therefore have to buy a replacement and then format it by Plugging it into the printer then go down to settings, and clicking the SD card option and then pressing format
Hope This Solves your issue
William
thanks hopefully this works now thank you
hey guys im new ok so a lasy night got this erros message 0300 08008 and now my tool head is not heating up propely
