ABS support material does not work
Drying changes nothing the material just refuses to adhere to anything even itself at times. I am trying to use it so that the supports release a little better from a seal groove that runs the inner perimeter of a rectangular box that serves as a dust cover for 16mm film magazines. I am using defaults in bambu studio 2 i did try changing the extrusion from 90% to 100% but that changed nothing. I also tried just using it for support contact points but that didn’t work either. I am convinced this material is just useless. I cant imagine using it as a raft so it can pull up mid print and trash your print head. yes its been dried at 80c for 4 hours(and longer) inside my ams-ht. I thought this material was supposed to still stick to ABS but provide a looser boundary than ABS/ABS instead this stuff just doesn’t stick to abs top surfaces at all and creates a very rough contact surface on the bottom more-so than just using reg ABS supports. what is wrong with this material and its profile?
