Bambu Studio Access Violation When Slicing Specific Model
Summary
Bambu Studio consistently crashes with an Access Violation when attempting to slice one particular model.
The same model slices successfully in OrcaSlicer, which suggests that the geometry is valid enough to slice and that this may be a Bambu Studio-specific issue.
Environment
OS: Windows
Previous Bambu Studio version: 2.8.0.50
Current/latest Bambu Studio version: same problem after upgrade
Model created/exported from Autodesk Fusion
Problem
When slicing the modified flasher body, Bambu Studio terminates with an Access Violation.
The crash is reproducible.
I initially suspected a problem with the 3MF file, but the same behaviour occurs after exporting the model as STL, so it does not appear to be caused by 3MF project metadata.
Tests Performed
Original 3MF in Bambu Studio → Access Violation
STL exported from the same model in Bambu Studio → Access Violation
3MF in OrcaSlicer → slices successfully
STL in OrcaSlicer → slices successfully
Upgraded Bambu Studio to the latest available version → same Access Violation
The issue therefore appears to be specific to Bambu Studio’s handling of this particular geometry rather than a generally invalid model.
Expected Behaviour
Bambu Studio should slice the model normally, as OrcaSlicer is able to do with the same geometry.
Actual Behaviour
Bambu Studio crashes during slicing with an Access Violation.
Reproduction
Start Bambu Studio.
Import the affected 3MF or STL model.
Start slicing.
Bambu Studio crashes with an Access Violation.
Additional Information
The model is a modified version of an existing design which previously sliced without problems. The crash started after changes to the geometry.
The model is commercially sensitive, so I would prefer not to attach it publicly to the report. However, I am happy to share the model privately with Bambu Lab engineers/support if they are interested in reproducing and investigating the issue.
I can also provide the original working model for comparison, together with Bambu Studio logs or crash dumps if required.
