Add extra information to project
Currently the option in Bambu Slicer > Project > ‘‘Information’’ does not function. There is no way to add information about the project.
I would like to see this available again. Being able to add comments, descriptions or even notes to a project. For me and probably others this can be very important.
When I use Bambu to create prototypes, I sometimes have several plates with different versions of a model for testing. The only information I can add is plate title, this is very limited!
If I could add notes per plate that would be perfect. This could also be handy for models uploaded on Maker World that are spread over multiple plates.
Otherwise, allowing users to add comments or project information again on the Project page would be great! Please enable this again Bambu!! Thanks.
Currently this area is filled out when you upload to makerworld. You could try uploading as draft or private then redownload the resultant .3mf to have the data populated. This is just a workaround and not precisely what you asked.
I’d like to see a option in the software.
Right now I am writing notes to keep track of changes to slices. Just makes more sense to be able to do it in the slicer where the changes are.
I don’t really want to publish files on makerworld that won’t end up there.
