Hey there, I have upgraded to a 0,4mm E3D Obxidian nozzle for my X1C some time ago.
As adviced, I have reduced temperatures by 10°C in all profiles because the temperature sensor sits opposite the heater instead of same side in the stock hotends
In many respects, the improvement is stunning me. For the materials I tested, maximum flowrate until first defects appear has increased from 21-23 mm³/s to 40-45mm³/s using the max flow test in Orca. I have set max flow to 35 for all materials, even non-HF ones.
Surfaces e.g. of regular PETG look the same from 100-300 mm/s.
And layer adhesion is now constant no matter if I print at 100 or 300mm/s and way better than it was at 100mm/s with stock hotend.
There are two things though that bother me and I hope to solve with your help:
1.) oozing during print preparation.
when the printer purges the nozzle, cleans it etc., there is a lot more oozing now. That gets dragged far more often on the build plate than before. I heard that this is typical for CHT nozzles. With the arrangement of heater and sensor in mind, I thought it would be a good thing if the printer reduces the temperature by 10°C during all those preparation steps. Eg do purging at 240 instead of 250°C, while cleaning, cool down to 130 instead of 140°C, …
Does anyone know if this is part of the gcode or is it hardcoded in the firmware? If in gcode, can someone point me in the right direction?
2.) insufficient purge at print start.
The second issue is very similar: Apparently the CHT nozzle needs far more purge volume to really clean the nozzle from the last filament. When starting a print with a different color or material, the first layer is usually still colored from the last filament. For clean prints, I have to manually load the next filament and push some through with the controls. I would much prefer, that the printer just purges more at the start of a print. Same question here: does someone know, if I can adjust that in the gcode?
To all users of an Obxidian or other CHT nozzle: Do you share my findings? Are there other issues I didn’t discover yet? Did you do something about it?
If there isn’t much feedback, I will ask E3D. The nozzle is expensive enough and developed in cooperation with BambuLab, so they should be able to provide the same experience as with the stock nozzle.
