Advice: Check the cushion pad in the top right. It left a mess
I got my H2S last year soon after its release and ran into an annoying issue over the weekend. In the top right corner of the printer is a cushion pad - probably meant to reduce noise or prevent abrasion when the PTFE tube touches that spot.
Unfortunately, it fell during a print and ended up in the belt, pulley, and motor system, leaving a lot of debris behind. My guess is the glue or tape holding the pad isn’t strong enough for higher chamber temperatures.
It’s probably worth to check that regularly or remove it / further secure it. Replacing the PTFE tube every now and then would be much less hassle than this dirty mess right now.
I’ve contacted support to see how they handle it and to make them aware of the problem. Luckily one of the printer videos catched the situation as well.
May I ask how many high temp hours you have already printed?
I am on 1800+ hrs on my H2D, of which approximately 300-400 high temp hours, but I don’t see any signs of loosening.
Still thanks for the heads-up though.
1745 hours, with some higher chamber temp prints every now and then (ABS / PA).
Seems like a bad batch then. Or some grease on the surface before applying the sticker.
I guess it will work fine without, but the noise could increase.
An early adoptor / first batch issue is possible. Ordered it in August 2025 right after release.
Will see how they handle this and then learn from it for the upcoming launch that I’m looking forward to.
The bad part is that the belt moved and spread the debris around.
My H2D is of May 2025. So older than yours.
That sticker sits in the entire H2 series.
I must admit, high-chamber temp prints do deform the cushion, but at a negligible pace. I also got my H2D (laser-ready) in August, and while the cushion has deformed absurdly you can see the mark of the cable chain when it grinds against it and shrunk in size a lot, but its still very usable. I have ~2,400 hours on it, probably under 200 hours of chamber high-temp printing. Won’t replace until it gets teared.
This cushion exists on all core-xy Bambu lab printers, its just that the cushion on the 256mm plates are much smaller and square-shaped, these machines I’ve seen haven’t worn those down for two years under constant usage (public X1Cs in libraries).
From my experience you most likely didn’t get a defected machine, since in that case, other things would’ve shown up too and you would’ve had this issue well under one whole year. I think it may have gotten damp or it induced a small tear on at some point, which then got worse every time the cable chain dragged against it. It could’ve also been an old adhesive, and the high temp chamber printing melted it, making it smush into itself whenever the chain dragged against it.
What I can imagine is that for some reason the glue wasn’t applied correctly or maybe there was some grease underneath it like someone mentioned.
I’m usually following a lot of forums and subreddits and I haven’t seen this issue before so I guess it’s not a “big / common” thing. Guess I was just very unlucky with my machine.
But it might be a thing that’s worth to check from time to time to go sure that it’s not getting loose.
What is the red… stuff? here… rust?
On the rub pad, personal experience,
March 2025 H2D not a lot of high temp, 1900+;
Jan 2026 H2S that prints the most hight temp, 1200+;
both are doing fine here.
Not the biggest fan, not so much the pad but the textured light bar directly above that rubs off tiny chunks of PTFE when objects are located to the far right edge, so I regularly check this area (and PTFE) for damage or cleanups.
I can rub it off and it’s just in that corner. It must be the particles / debris from the fabric / pad that got crunched in that area. It got stuck by the belt and pulled all over the right side of the printer.
Just did my regular maintenance (every 3 months) a week or two ago and by then everything was perfectly clean.
