Yeah I’ve recalibrated after downgrading the firmware. Still the same problem unfortunately:((
This has just started to happen to me out of the blue… and i have no idea why… Ive been using the same G-code and everything… no idea why all of a sudden my print bed is about 1mm to low for the nozzle now! anyone else?
I think I’m having this same problem, I just turned my Printer on after a week, had to find a hex key to unclog the hog end and took me some time to find one the right size.
anyway the first calibration i did failed for some reason, so i restarted and tried small item as a test print and the leveling usually does 4 taps ( for lack of better words) on the bed in each corner then progresses across the bed starting at the front, only now it doing 4 taps in some spots and 7-10 in others along with the shaking of the bed.
then when it starts the print the test bit that goes across the bed at the very front comes off half way through, i checked the bed type and it’s correct.
yet nothing is sticking.
i cleaned it with Iso alcohol 90% and yet it still won’t stick right.
I’m starting to think the recent update that downloaded when I started up bambu studio maybe the cause, as prior to it last week the print was leveling fine.
Hello, I have the same issue with P1P. The printer came out of the box with firmware 1.0.5. It prints well, but the camera did not work. I updates the firmware to 1.0.8, and did the calibration, and have it do the leveling before each print, but the nozzle is too far away and the material never sticks to the plate. I tried all the firmware versions between 1.0.5 and 1.0.8, recalibrate, but none of them work. Going back to 1.0.5 fixes my issue, but the camera only work for 1.0.6 and up. This is a bit annoying, as it seems there has been no resolution to this issue.
