Alerts via MQTT?
I am using an Bambu H2D Pro on a local area network only. I have not connected it to the cloud and do not intend to do so.
I am looking for a reliable way to be alerted if any issues arise during printing (e.g. filament runout, AMS errors, print failures). My preferred communication channel is email.
One approach I am considering is using an MQTT bridge to capture printer events locally and forward them into my building automation system (IP-Symcon), which could then generate email notifications.
Does this seem like a reasonable and robust approach? Are there better or simpler alternatives for achieving reliable alerts in a LAN-only setup?
Many thanks for any advice!
Home Assistant has a pretty nice Bambu Lab integration that I believe still functions via MQTT.
Would save you the effort of having to develop the integration yourself.
Might wanna check that out!
If you have an MQTT client listening to your printer, you can do literally anything at that point. I have a simple client that parses the printer’s messages and sends a txt to my phone when the print is finished. I don’t do sophisticated error monitoring because I don’t get errors… :slightly_smiling_face:
