AMS 1 failed after perfect first layer print
Hi, I’ve a A1 mini and I’ve connected my AMS 1. Filament loading work as expected, print start, first layer is perfect, then there an issue. It seems that the AMS do not “push” the filament throught the the PTFE tube, expect for loading.
I did not found what wrong.
Any help apreciated.
Thank you
What do you mean AMS 1? If you mean the AMS Lite then it should work, if you mean an AMS then it only works with some additional hardware, the AMS Hub
so yes, I’ve the AMS Hub for AMS first generation
Oh I see, sorry can’t help I’ve got the A1 and AMS Lite
I’ve finally fond the issue: there is an AMS setting that keep the filament as detected. Once put this setting off, the AMS has been working successfully.
