I’ve got a question about AMS’ auto-refill feature on my P1S. I’ve had this happen twice now.
I’ve printed with Slots 1 and 2 being Bambu PLA refills with the RFID tags. Slot 3 is Support for PLA/PETG.
When Slot 1 runs out, it will switch to Slot 2. However, after the next Support run, it tries to use Slot 1 again, because of that, it will complain about Slot 1 being empty. If I move to Slot 2 to Slot 1, it will use Slot 1, but after the next support run, it will try to use Slot 2. It’s trying to alternate between 1 and 2 after each support run. I have to refill the empty slot before it continues uninterrupted.
Is there a way to make it just switch to 2 after 1 runs out?
Firmware is up to date, AMS auto-refill is enabled, color and types are the same. Not sure if the pic is related. This dialog is pretty un-intuitive. When you first open the dialog box, there is no grey arc on the top half or lower half. However, when you click on the top or lower half, the grey arc goes to whichever side you pick. I have no idea what this arc does.
