this is happening with the latest software downloaded.
so i had no filament loaded in slot 2
but 1, 3 and 4 where loaded.
but in the software it said 1,2 and 3 where loaded.
so my loaded filament 3 and 4
where 2 and 3.
i didnt check if it would print, i added a roll in the second slot. to continue.
so please fix this issue.
thank you.
Did you sync and override the AMSes in Studio? They changed how it works in V2
yes i seen and i did, but still that same issue.
and if you manage, sometimes it adds the filament instead of change.
so i think something is going wrong in the software.
They are NOT slot numbers, just numbers. Click the dropdown on a filament and you’ll see the slots are labeled A1, A2, A3 etc.
Stupid, I know!
but if i put my tpu for ams in slot 2
it is showing as 2 and not as b1
but ill recheck im confussed now, hihii
you are correct.
they need to change that, or am i crazy. hahahahahaha
because , serious question, what are these numbers for then.
because.
if you always would skip 1 slot, its never correct.
if you have all slots filled youre fine.
thanks problem solfed, at least i know what is happening hihihihi
I think of it like this
Or this. “D1” = “8” = “39” = “PA1”.
They should settle on ONE standard in Studio.
i think to simple hahahahaha.
Begin:
Slot1 = 1
Slot2 = 2
Slot3 = 3
Slot4 = 4
if slot(var) = EMPTY then Skip:var=var+1
Send BambuStudio
End:
hahaha
