AMS gears and rollers locking up
That is another issue, which is understandable as it follows the laws of physics, but this issue I’m having (and maybe the OP) is even a full or half used spool will ride up in the AMS and the feeder unit will be aggressively trying to take it in. Sometimes I’ve had to use my fingers as a spool holder and let it spin freely to load.
@Wizardbynight What type of filament spool are you see the problem with?
Bambu PLA amongst others. Doesn’t seem to be material specific
Printer: P1S
AMS Model: AMS 2 Pro
Filaments with issue: at least PLA
I’m joining the Gear-Lockup gang as well and even made an account just for this. This happens more often for spools at <50% capacity and in slot 3 for me. It seems like the feed motor and front rollers desync. Normally, these 2 pieces sync up to pull & roll the filament in and out of the printer in unison. However with this issue it seems the feed motor pulls on the filament, expecting the rollers to initiate, but encounters massive friction. If people have been disassembling, lubing and replacing parts to no avail then a firmware update should be appropriate.
Try a spool weight, you print a carrier for the center of the spool. There are other solutions in the works. There is an internal lever in the prefeeder which gets stuck.
Joining the group. I am failing all of my recent prints due to this locking up issue. These are all great solutions and is any one solution coming to the top of the list?
Weights? Do they actually work or not? I feel that they are going to keep the spool in place better but that is just going to cause it to pull onto the stuck roller harder.
Cleaning - yeah it is a pain but does it actually work?
What about the arm? Could I add a weight to the back side of that if it is getting stuck and help it disengage better?
I am open to anything but just want to start with something that might have a chance at working
The main solutions presently are , weights, the feeder savers (Extension of a PTFE tube to the height of the filament, is a common theory), third solution is spring loaded rollers in the center of the spool. I have two additional solutions in testing. First is a rod thru all four spools which is adjusted to touch the spool when it moves forward, Second is two bearing at the prefeeder, when the spool moves forward it touches the two bearing and allows the driving roller to lose traction. They all seem to work and then they don’t (except my solutions in testing have not failed yet). I am not aware of a rock solid fix yet….
I am having the same problem the rollers seem like they lock up until I break it loose. Have you had any luck.
Same boat here… pretty frustrating to be honest. I spent a lot of money for the setup and an now back to single filament prints.
I have been in this fight a long time, tearing my hair out. I think I have spent about $600aud trying to fix whatever was going on. Bambu support has been worse than useless with it.
I suspect I know what is going on here, I will try to describe it.
Inside each ams channel there is the control module that has a dc motor inside. It can only go forward and reverse, so the module can only take 2 actions. when its positive it is forward and it runs the feeder. when its negative its backwards and runs the roller.
As it only has 2 actions, it can only do 2 things.
  1. Pull filament forward with the feeder
  2. Reverse roll the entire spool.
It cannot actively either reverse the filament or roll the spool forward. Those are passive actions. The filament is reversed by rolling the spool, and the spool rolls forward when it is pulled by the filament.
The gear train is driven by a worm drive, which is what gives it its power. Worm drives cannot be backdriven (ie other gears in the train force the worm gear to rotate). This is important to note.
When a channel feeds filament, I believe it only feeds it only as far as the main feeder unit at the rear of the ams. once it gets there it hands over and disengages. This is probably because keeping both systems in sync would be a pain, you would need buffers, sensors, etc. So it has to disengage the filament feeder. To do this, it must reverse, because its a worm drive and it cannot be backdriven, so to freewheel the gear train must be disengaged. Because it only has 2 actions, in disengaging the filament feeder, if it overshoots it will engage the roller, which can only be driven backwards, and again, to freewheel must not be engaged with the worm drive.
So this is where we get the lockup, it pulls the geartrain off the filament feeder, slightly overshoots and engages the roller drive. Because of the worm gear, this freezes the roller.
If you describe this as a state machine, the thing has 3 states. FEEDFILAMENT, NEUTRAL, REVERSESPOOL. It’s essentially like a motorbike where you are trying to find neutral and overshooting.
You can verify this because you can feel the roller is stuck frozen when its in this errored state. if you wiggle it, you can get the geartrain to disengage because the mechanism that pushes gears into/out of engagement is itself just a free spinning frame that relies on the force of the gear teeth to move.
When you have a heavy full filament roll, the weight of it presumably is enough to overcome the tiny teeth on the roller gears and it can bump the geartrain out of the way.
This is why this issue is so intermittent and hard to debug. Motors and the components in the motor drive chain (caps, inductors etc) will all have small variances and may change with age. The firmware might be misconfigured etc. But essentially its a design flaw. The main design flaw is that there is about 4x main gear movement available to disengage the filament feeder than there is to disengage the roller, so it takes very very little margin of error in disengaging the feeder to engage the roller.
Theres lots of fixes i can think of, none of them great.
  • Ratchet style teeth on the gears that engage the feeder/roller so the direction of freewheel will naturally disengage the gears.
  • Cutting into the lower housing parts to give much much more travel downwards space so the pulse error room is larger. DIY-able. If someone has a good step file for the lower grey half of a feeder, 3d printing a swap might be a smart fix.
  • Firmware changes to a much larger pulse that will absolutely engage the roller, and then pulses short the other way to disengage it (since the feeder has so much more margin/travel room)
  • Feeder gets a one way bearing so anything pulling filament through lets the thing freewheel without having to disengage the drivetrain, but it can still drive filament through. Or the roller gets a one way bearing so it can always roll forward but can be driven back. Something like a HF0306 could fit inside the drive side of the roller. If you have the right tools i think you could make this part.
  • A small spring keeps the roller drivetrain disengaged when not actively driven. This is very tricky, not a lot of margin to make it work, ie the force to overcome the spring must be less than the gear train force, and more than the friction of the frame.
Weight in the filament roll can help it seems due to being enough force to push the gears out of alignment, but its not a good fix for many obvious reasons. I think all the other fixes people have described are working on this principle or are placebo.
The ams is well engineered in the sense it smartly does just enough, ie the design stays economical because its not filled to the brim with motors and sensors. A good example of taking away until you have juuuust enough.
But it would be a much, much better tool if it could detect filament not moving even if the feeder is feeding and not carve into filament. they already do detection on something like this from memory (i dont want to disassemble my ams right now) where they have a magnet and hall sensor, but i think its either on the motor side or they are not smartly using this information. In the same way, if it could detect things like the roller not moving it could be much smarter. This failure mode of feeding filament with a jammed roller is just the worst. I have sworn heavily at this thing, i bought another ams. i replaced all the parts in my ams. I replaced my toolhead board. lots of money out of my pocket to save bambu a few cents on their per unit ams cost.
Anyway. if anyone has feedback on the idea, they can verify it or clearly disprove it, or has a good idea for a fix, i’m all ears.
Ams gears lock up due to resistance , leaving spools of filament in the Ams for periods of time while its not being used, can also cause the rollers to lock up they are locked up by design to prevent damage , simply lifting spools up slightly unlocks them , (Ams 2 )
An image of the gear that locks the rollers
I have two working fixes, I will try to post one soon.
your roller is different to mine,mine the gear is the same diameter as the roller, yours is larger. is this an ams1 or 2?
I will note the issues i describe are every single time i use this ams, and have nothing to do with that channel being unused for some time. it’s so much work to get this ams to feed that i would be way way better off manually feeding.
I have had penty of feed issues, but they have all been resolved. Now zero feed issues… Number one issue was the 180 degree PTFE tubing bend from the AMS units above the printer, I went to a rigid routing and it works. Second is providing the AMS with external power, Third, no cardboard spools
Here is the “Stuck AMS 2 Pro spool roller fix” that is working for me. Please provide feedback if you try this mod. Thanks. Possible AMS Pro Spool Jumping - Roller Freeze Fix - Free 3D Print Model - MakerWorld
How are you supplying AMS units with external power? are you finding appreciable voltage sag?
I added a 24v 10a power supply, that powers 2 AMS units. To me the motors in the AMS sound much stronger when you have external power. If there is no external power, sounds like the motor can bare move the filament. Highly recommend external power.
I have one brand new AMS2 Pro out of the box that pretty much is trash. Got it as part of a Combo Purchase I just made of the X2D. All it does is go back and forth back and forth. Locks up and sometimes reads the correct Color. Not even sure RFID is working properly. Oh and here and there it has recoginized the spool. I am using the recommended PLA Basi from Bambulab. ANy advice will help.
Does not sound like a stuck front roller.
Is the filament making pass the AMS internal hub, if not
More like the issue noted in other threads where the hub halfs are too tight, some people loosen the screws a little and others add tape shims between the two halves of the hub.
See this post
If it makes it out of the AMS but not to the extruder, then try increasing PTFE tubing bend radius, powering the AMS, and rerunning the AMS setup. Also don’t use cardboard spools!
So is there an offical answer from Bambu for rollers that stick?
