Excellent idea. I had not attempted this. I ran the AMS-HT directly to the printer bypassing the 4n1. It printed flawlessly.
So we had a success there.
When I connected it back to the 4n1, it errored out.
So I focused on the PTFE from the 4n1 to the printer.
I ran a stiff filament through the PTFE and found that the 4n1 is where it got rough. I swapped it from one of the four holes to a different hole and it got smoother. However, when it tried to exit the 4n1 to head to the printer, it definitely got stiffer. There’s a place at the exit where it almost “clicks” as it exits. I pulled the tube out and trimmed it several times trying to alleviate the “click” - no joy. It won’t allow for a smooth exit. Neither will the other 4n1. And oddly enough, my spare 4n1 does the same thing. No idea what’s going on with that, but it’s definitely a rough patch for resistance. All three of my 4n1’s bear this out.
In order to alleviate any sort of resistance, I unmounted the twin 4n1’s from the computer (BL printed mount) and let them hang freely. That allowed the PTFE’s to relax as much as possible.
I swapped out the PTFE from the 4n1 to the printer (I’ve done this several times, but I realize just how finicky these can be) and it failed. I put a longer PTFE on there and tested. When it failed, I trimmed a bit off and repeated the test. I did this each time it failed. Eventually, I was able to load the filament ok without error.
With the filament loaded, I attempted a print - no joy.
I mounted the 4n1’s back to the printer and focused on the PTFE’s again. I did some microfine snips to the end of the PTFE where it leaves the 4n1 and seated it. I loaded the filament and attempted a print - success.
I unloaded the filament to set the machine to idle (all filament unloaded and the machine ready for action).
With the filaments in the AMS-HT’s and the printer idle, I ran three more test prints on both the right side and the left side utilizing only the AMS-HT’s - success.
My takeaway - the 4n1’s need some work. There’s a place at the top where the filament exits the unit enroute the printer where it seems to somewhat hang-up the flow. Not sure what’s going on in there, but it’s definitely happening in all three of my 4n1’s at multiple angles with multiple lengths of PTFE. I can fine-tune the PTFE, but it doesn’t alleviate the “grab” there. Also, not all of the ports (the four entry ports at the bottom of the 4n1) are created equal. One of the ports flat out would not allow the filament to pass through smoothly. Three did. One of the other 4n1’s suffered from the same bad port. The third seemed to be ok.
These 4n1’s need more attention.
Thank you so much for the assistance. I genuinely could not have gotten this far without the help.
And user_2463535618 (if that’s your real name), outstanding idea on how to proceed.
Understand, this states that there is a solution. But the truth is, the only solution would be for BL to refine the design on these 4n1’s. Or perhaps refine the manufacturing quality control? Anyway, that’s the issue at play.
