I have an AMS Lite. Whenever I use the 250g/roll (the smaller ones) in the AMS Lite I keep getting filament is stuck/tangle errors. Why is that? Does anyone have this experience?
If I use the AMS Lite with the larger spools, everything is fine.
What spools are you using? Is the diameter significantly smaller?
That message pretty much means that the motors are working harder than they are supposed to.
It would also be useful to see pictures of the setup.
Whose filament are you talking about, some of the small rolls from off brands don’t have the tight tolerance better filament manufactures have; i .e. +/- 0.3mm. They are marketed as sample rolls, best used on the external spool, not an AMS. I have several speciality small rolls (i.e. wood and metallic) which I don’t use the AMS to fed them into the printer and never had an issue getting them to work.
Those spools usually are “curled” a little more than regular spools and sometimes feed error as their leading edge gets caught on fittings. But if yours are getting tangled midprint, after plastic has successfully started flowing, you might be running into real errors? Is the filament actually tangled/knotted on the spools?
I was referring to the diameter of the spool itself, not the filament on the spool.
To throw my guess into the mix: It’s probably not the spools, as these 250g spools should actually fit on the AMS Lite without any problems, since they have the same diameter. Of course there are exceptions! As already mentioned, a photo would be useful here.
I suspect something much simpler. When loading or changing the filament, either no filament clip was used, or the tension was not maintained. At some point, the filament must have become tangled. This is not immediately noticeable, of course, but it takes around 5 to 10 minutes of printing before the tangle becomes significant enough.
This happens more easily with the small spools because they are wound more loosely. Not loose, but less tight. But hey, maybe I’m totally wrong. ![]()
I was thinking that less likely because they implied that this is happening on more than one spool.
Unless of course they really dont know how to handle filament.
We’ll probably never know if we look at OP’s profile, but I was already aware of that when I wrote my own comment. In the sense of: Solution is not marked, no feedback, disappeared. ![]()
This is just another one of those threads where someone asks a question and never responds.
It could be any of 100 answers.
Since the OP gave up, I’ll take it from here.
I’m using 250g spools from Sunlu which are a great choice to give the children many color options on the A1L + AMS lite without breaking the bank.
These spools have a much smaller inner diameter, so you can’t get them all the way onto the AMS lite.
Because they have a smaller inner diameter and the AMS software has not been designed to deal with that, they constantly run behind and declare a tangle error where there is none, especially towards the end of the spool.
Overall, this is just bad design, they could have adaptive speed when the extruder is pulling on the AMS lite motor, but instead there’s a dumb one size fits some solution in place which makes smaller spools from mainstream manufacturers unusable.
At this stage, either bambu recognizes this as a bug or anyone with that problem will have to respool the end of every single 250g spool if they want to use the AMS.
I understand the frustration, but Bambu really isn’t at fault here. When the AMS Lite was released, 250 g spools were practically nonexistent on the market. It wasn’t until customers like you - people who enjoy trying out lots of colors, for example for their kids - that any real demand for smaller spools started to appear.
The AMS Lite has been on the market far longer than 250 g spools have even been a thing. So yes, as inconvenient as it may feel, the AMS Lite was designed around the spool formats that existed at the time - not the 250 g spools that only arrived much later.
By the way: You’re paying €20 for 1 kg when buying the Sunlu 250 g color set, compared to €10 for a regular 1 kg Sunlu spool. In other words, the price is essentially doubled simply because the product is packaged as a color variety set. For that price, you could have gotten a regular spool and still had lots of different colors for the same price.
You’re basically paying an “idiot rainbow-color tax” and I don’t mean that disrespectfully, it is criticism directed at Sunlu. Sunlu is ripping you off.
Obviously, you don’t personally see any value in these 250g spools.
Much like a teenager who would tell you good beer is not worth it because you get less alcohol per dollar, you seem to believe $/kg of filament is the only metric that could ever matter to anyone on earth.
It’s fine but you should normally be able to realize by yourself that the whole market can not possibly be 100% just idiots who like to pay more for stuff.
As I explained very clearly, this enabled my kids, on a limited filament budget, to try out dozens of colors. By your own math, at least 2x more.
Anyway.
The AMS lite could have been patched a long time ago, the code was not very smart to begin with, it might have taken a while to become obvious but it’s still a bug.
Bambu doesn’t need you to pretend everything is fine, they need you to help them make this product (or the next gen) better by submitting useful real-world feedback.
Then you misunderstood my point. My main concern was the price and the incompatibility - you’re paying twice as much for less material. You have to respool it anyway, as you said yourself. You’re using an AMS Lite that isn’t designed for that.
So where exactly is your value?
It would be correct if you said: “The spools make sense because I use them on the external spool holder.” These 250g spools are better suited for use on the external holder.
Edit: I checked just to be sure. Bambu lists such spools as incompatible for AMS Lite, and Sunlu itself does not adhere to Bambu’s specifications. So this has been confirmed by both sides.
Why should Bambu modify their hardware design and software to support a spool format that they don’t produce?
Yes, I know Bambu has introduced a sample set of 250-gram spools, but even those are meant to be used on a plastic reusable spool.
You could just use your 250 gram Sunlu spools on the external spool holder. (beat me to it, lol!)
Can I ask how you know what the closed source AMS Lite firmware looks like?
Anyhow, the tangle error isn’t at all based on the speed the spool runs at - it’s not that they’re “running behind” as the AMS lite isn’t counting revolutions. The A1 series relies 100% on the extruder to pull filament in, and the tangle detection is due to the extruder seeing excessive force to pull in filament, and that seems to be due to really poor feeding angles between the spools and the filament inlets - because the spools don’t fit on the spindles properly. A smaller spindle would fix all this…
It isn’t a bug for the extruder to say “I’m having to pull too hard!” because regardless of the cause, it’s having to pull too hard! you want an override for this? Fine, now it won’t detect tangles for regular spools, and now you get filament breaks instead. Or underextrusion. And keep in mind…**the mini spools can still get tangled up also **.
Or you could have some fun printing and building a respooling machine with your kids, then you can transfer the mini spools over onto suitable reusable spools with a correct inner diameter.
Thanks, could you please point me towards the not-out-of-stock PLA, PLA matte, PLA silk, PLA dual and tri color silk bundles from Bambu ?
Thank you for this helpful reply, I’m going to try this adapter, I would rather avoid respooling if I can, there’s about 40 such spools.
I’ve disabled the tangle detection for now, I haven’t had a tangled spool in at least 100kg, and the Sunlu I get don’t seem to have those issues from the factory.
You’re right, the AMS lite does not work the way I thought it did, the spools do not have any motors, so it’s really a hardware design flaw and there aren’t many software fixes for that. Push/pull with the feeder motors or a variable tangle threshold are about all I can think of right now.
The kids still have to finish rebuilding the Voron 2.4 before we start another 3d printing related project.
