Hello Bambu Lab Forum,
A piece of filament is stuck in the AMS in the PTFE inside the AMS,
The PTFE tube has been removed from the front of the AMS but Bambu admits that the
PTFE tube at the back of the AMS, where the four tubes come together is not removeable.
Attempts to remove the blockage by inserting filament and wires thru the PTFE at the front of the AMS and thru the back of the machine will not budge the stuck ABS filament.
Bambu Lab support is very poor. The only way to reach Bambu Lab support is by email. There is no telephone tech support or chat. Bambu support readily admits that it takes two or three days by email. Support has been contacted several times by email. After three days they sometimes reply to the email (sometimes not) with an answer that either does not work or has nothing to do with the problem.
The only solution offered by Bambu support was disassembly or replacement of the AMS internal feeder unit. A replacement of AMS internal feeder unit was requested but no reply has been recieved. The ticket, details copied herewith below, opened was opened on May 6 2026 and is staill marked âpendingâ.
Two questions please:
- Is there anyone who has contacted Bambu support and not had completely abysmal experience?
- Is there anyway to remove the blockage in the AMS? Is the only solution buying a new $300 AMS?
Thanks.
Allen Pitts
Dallas TX
+++ Bambu Lab Support Ticket ++++
Bambu Support Ticket No: US260521607006
Printer Model (or Product) H2S
Issue Type AMS(Automatic Material System) Malfunction
AMS Load Filament Failure
AMS Failed to Send Out Filament
Issue Description
âAMS 2 Pro rear manifold jam. Filament is stuck inside the rear PTFE outlet block and cannot be moved from the front or back. The rear PTFE tubes are nonâremovable on AMS 2 Pro. Requesting rear manifold service or replacement.â
49.22 kB
+++ End of Bambu Lab Support Ticket ++++
