AMS Motor Overload
Hello everyone, hopefully someone can help me out. I’m having an issue with Slot 4 on my 2-year-old AMS (Generation 1) paired with a P1S printer.
I constantly receive a “Motor Overload” error specifically for Slot 4. Initially, I thought it was just a poorly wound filament spool causing the issue. However, it now happens with every single spool I try. If I move the exact same spool to any other slot in the AMS, it prints perfectly fine without any errors.
I’m considering replacing the motor for Slot 4. Has anyone experienced a similar issue or have any advice before I buy a replacement part?
Thanks and best regards!
Could be several things. Key is a good inspection, in particular of the most likely parts to experience wear.
When that happened to my slot #2, I first replaced all internal PTFE’s but then realized that the AMS roller shafts were worn through (asymmetrically, probably due to a filament clip I used).
Fortunately, that was it in my case.
Before buying a motor I’d pull all filament and look into slot 4 with a flashlight. The feeder gears tend to pack up with filament shavings after a few grinds, and a soft brush or compressed air clears them. A snapped bit of filament stuck in that slot’s path gives the same symptom. If both are clean, the motor is the next suspect.
Thanks for the replys. I already replaced the support shafts/rollers a few months ago because the rubber part had a lot of wear on it.
I will give the whole slot 4 a closer look, at the first look I did not see anything wrong with it. And I am going to clean everything.
Thanks again, I will let you know if it works again or if I need to buy the replacement part.
Just a quick update on my AMS Problem → i solved it with the replacement part for 9€ for the feeder unit. The kit only includes the AMS feeding funnel and you have to disassemble the whole feeder unit. I also replaced the tubes inside the AMS with new ones because some of them showed some wear. After a few multicolor test prints I had no problems anymore so we can close this topic now.
