Hi There!!
One of my filament feeders is failing to push the filament through the internal hub. I checked the internal PTFE tube and its not clogged. I also moved the filament around and it works fine, but that specific feeder is stuck. I’m not sure what todo. the rest of the feeder work completely fine. I printed a quite complex item with 3 colors and it had no problems.
This is a video of the problem. I greatly appreciate some advice!!
Thank you,
Amir
