A purge tower won’t be generated, even if enabled.
I do seem to have found the solution and it is indeed a bug.
If i slice it with Skirt “Off” - no skirts will be generated
if i slice it with skirt “on” - it will generate the skirt around all models and those per model skirts.
if i THEN untick skirts again and let it slice, then the skirt around all models will disappear but the per model skirt still exists. The only fix would be to reload the project so the plate is loaded with skirt not enabled.
I recorded it to make it more clear. Watch in Fullscreen to see it better.
