You may find this helpful.
It was created to help with specifically this kind of issue.
It’s important to remember that the motor has to deal with both the forces to pull the filament, but also to push it (for which there is quite significant resistance).
Mods like the Y adapter for rear feeding will likely make this resistance worse so bear that in mind if you’ve got anything like that installed.
