AMS2 Pro compatibility
Hello everyone,
I have a P2S with an AMS2 Pro. Is it compatible with the A2L?
Or do I need a special AMS2 Pro for the A2L?
Thank
there is no special version of an AMS 2 Pro
your current AMS 2 Pro will work with the A2L
if you only have one ams unit you will need the PTFE coupler which is included with the printer
Thank you for your reply.
I have another question.
Can I connect the AMS2 Pro to two machines at the same time?
There is only one PTFE output on the AMS.
That is not possible
You would have the feeding issue and software issue
Thank you for the information.
You will need the AMS power adapter to use the drying feature. Otherwise, everything plugs straight in, I got mine set up like this:
