AMS2-Pro temperature Humidity Sensor replacement
I don’t seem to have much luck with things lol … if i ever break something its the part i cannot find a replacement for .
can anyone see the Humidity Sensor for the AMS2 as a purchasable replacement part
It does not seem too difficult to re-solder though. Can someone you know do it if you cannot?
Here is the humidity sensor, which is glued into the black frame. If you only want to replace the sensor, you can remove it for replacement. The accessory purchased from the official store comes integrated with this black frame.Not sure if the translation is accurate.
