I installed a 0.4mm high flow nozzle as soon as I got my machine. I never even used the regular nozzle. Is there any problem with using the high flow nozzle at lower speeds? I want to make a few detailed prints at really slow speed.
From my research and slow printing experience, there’s no drawback or negative to using a HF over the standard. Print quality looks identical with the 0.4 HF.
Maybe someone else will come along with a different experience but as far as I can tell they’re identical.
When I need quality I print outer walls at 60mm/s and don’t have a issue with that with normal filaments.
