To the people that are running the revo, any special setting youve found work best with the high flow nozzles? Got my Panda care package today.
You’ll have to run flow and temp towers if you want to be precise.
Generally I have been running just a few degrees hotter (5-10) and bumping flow slightly. My preference is for the swappable nozzles and not speed. Others have posted their results with flow rate etc.
At stock settings you should see a little difference in print quality. I haven’t felt the need to adjust much. I believe if it’s working fine I’m not going to duck around and find out.
I’ve had issues with PETG with it that I didn’t have with stock. Could be just me but I don’t print PETG often. It has handled CF and GF filled ABS like a champ as well as CF PLA. If you try those you’ll need an obxidian or a clone hardened nozzle.
Thanks for the response… Much appreciated
