Any update to enable different size of nozzle?
i even would be happy if different nozzles would work when using print by object for different objects in the same print. That would be easy but is not possible afaik.
Multiple size nozzles would be a game-changer for us in so many ways.
Sorry for reviving this thread, but I´m close to ordering my H2C and I´ve been seeing other printers that are able to mix nozzle sizes in the same print, also seeing Orca has the ability. Wondering when BS will enable that feature.
Nobody knows. Even though it’s promised, it’s way overdue, so conservatively speaking you might just have to assume the answer is “never”. Even if promised, there’s no guarantee Bambulab will ever deliver on it for any of the existing models. Instead, Bambulab might pull a Creality and only provide it on some future model, which given what is already an extreme delay I’m starting to suspect is what will happen. That said, I don’t see any issue with the hardware. It’s a software issue, so it could be solved if Bambulab would give it priority.
Plus, who knows if the community is willing to port the ability with the latest drama. I haven’t kept up with the reaction of the community at large and what the amount of good will previous supporters still have.
AFAIK, Prusa is the only company with much track record on improving already released models. Bambulab has kinda-sorta done it, but not to the same degree. Creality almost not at all. Best advice: if it’s not there on Day 1, just assume it never will be. That way, if it’s something truly important to you, you aren’t trapped into a “Waiting for Gidot” scenario.
That said, you can extrude at 0.8mm line width with a 0.4mm nozzle. I do it all the time, and it works great, and no time lost switching nozzles. The slicer will allow as much as a 1.0mm line width off a 0.4mm nozzle. The fact is: if you look as the line widths generated by the slicer, they’re very often all over the map anyway, and for good reason. The main limitation is that you can’t get the same layer height out of a 0.4mm nozzle that you can get out of a 0.8mm nozzle, so that’s where it bites.
Now, here is a reason why they didn’t let H2D have this feature after H3C was released.
H3C seems has everything inside including a compatibility for diffrent nozzle size.
Yay the h2d will get possibility for 2 nozzle size in same print by the end of the month I wanted to print stuff in 0.2 with sturdier support on 0.4 I will finally be able to do so thanks bambu to support H2 series :hugs:
Where was that announced?
I guess this feature is covered by only H3C
