Anyone else put TPU through the AMS?
That is exactly what i just said, thank you for reinforcing.
The TPU filament is too soft to push back into the AMS so when the retraction is enabled, instead of pushing out of the extruder, it bends just above it. And the it gets grinded into a thinner strand which the extruder eventually cant use. So it stalls the extrusion even tho the print process continues.
No, it happens when you do manual load, select the filament, sit trough the process…, then it will start trying to load it, but the problem isn’t that the gears grind the filament and then it isn’t loading, for me, the problem is, that the filament doesn’t even reach the extruder gears to begin with. When during the extruder grabbing process I push the filament a bit, it loads fine and unloads without me touching a thing.
Now that i think about it maybe the AMS spring is to strong for it and it doesnt let it flow correctly :man_shrugging:t2:
So, I wasn’t aware of all the “don’t put TPU in an AMS” rules…
I already have used up half a spool of Sunlu TPU already, and never ran into an issue. Yet… lol
I do have the AMS 2 pro…
Do you happen to know the shure scale value?
TPU 95A is the most common and likely to cause problems with an AMS because it is essentially a wet noodle.
Was it that or something harder like a 68D, which would match what BL sells as TPU for AMS,
Yes 8 do, I got it on Amazon:
SUNLU TPU 3D Printer Filament 1.75mm, High Speed 95A
Keep in mind, I have the AMS2pro
All power to you.
Others have performed AMS hardware upgrades to get there.
All I ask is that you keep that in mind. Do not be too far away when it is running.
Can I assume you are not swapping between more than one TPU within the same model simultaneously?
Correct, not swapping or combining with any other filaments.
