Anyone got MTBF for various A1 components?
  • Printer model used
  • Slicer settings used
  • Type of filament used
I have had my A1 for about 5 months and gone through about 2000hrs of printing. In that time had a number 3 feeder on the AMS fail at less than 1000hrs, a nozzle heater failure at around 1200hrs, and recently discovered erratic heating of the hotbed which I suspect has been around for the last 600hours. Now I appreciate that the A1 is not a commercial production machine, but some of these failures are really very early in the lifecycle of the printer. Bambu has replaced the bits after some tardiness in identifying the problem despite my giving them some very clear hints, so I am not complaining about the customer service! However coming from the computer industry, we had a MTBF for every single sub assembly as well as the overall product and monitored this closely as this was the best (and only) way to pick up inherent flaws.
So anyone ever seen or heard of such numbers from Bambu?
Colin Louw
My first thought is, based on your math, your printer is printing 12 hours a day, 6 days a week.
You own an A series printer, a great printer (I have an A1 mini in my BL farm), but it isn’t designed to be a workhorse. It is in the entry level range of printers, this should give you some direction.
That said, it is expected to work well for a decent amount of time.
You have to remember that 3D printers are not yet an appliance, they have more consumable parts than other devices.
Bambu Lab has not published official, laboratory-tested Mean Time Between Failures (MTBF) figures for the A1 or its sub-components.
Some derived results, again, NOT based on published information by Bambu Lab.
Estimated Real-World MTBF by Component
The underlying components are categorised below by their operational lifespans under normal printing conditions (using non-abrasive filaments like PLA or PETG).
Component Category A1 Subemphasised text-Component Community Estimated MTBF (Hours) Primary Failure Mode
High Wear Consumables PTFE Tubes 500 – 1,000 Internal friction gouging, kinking
Silicone Sock 500 – 1,000 Heat degradation, tearing
Filament Cutter Blade 1,500 – 2,000 Dulling, failure to retract
Stainless Steel Nozzle 1,000 – 2,000 Bore widening (drops to <50 hrs with carbon fiber)
Mechanical Assemblies Extruder Gear Assembly 3,000 – 4,000 Tooth flattening, debris clogging
AMS Lite Feeders 2,000 – 3,000 Internal spring tension loss, gear slippage
Linear Guide Rails / Bearings 5,000+ Grooving, pitting (accelerated if un-lubricated)
X/Y Belts 5,000+ Stretching, tooth shearing
Electronics & Heating Toolhead Cooling Fans 4,000 – 6,000 Bearing failure, dust lock
Ceramic Heater & Thermistor 2,000 – 4,000 Thermal fatigue, wire fractures from vibration
Heated Print Bed 5,000+ Cable strain fatigue, trace failure
Mainboard / MCU 10,000+ Voltage spikes, component overheating
Maintenance Discipline: The MTBF of the linear rails, rods, and bearings relies entirely on user care. Neglecting to clean and apply grease or oil when prompted by the machine will induce premature mechanical binding long before the 5,000-hour mark.
Estimated Real-World MTBF for AMS lite Components
The lifespans below assume standard operating conditions using non-abrasive filaments (PLA, PETG). [1]
AMS lite Sub-Component Community Estimated MTBF (Hours) Primary Failure Mode Official Recommendation
High Wear Consumables High Wear Consumables High Wear Consumables High Wear Consumables
PTFE Feeding Tubes 300 - 1,500 (Highly variable) Internal gouging, friction increases Replace every 1–2 months (100–300 print hours).
Rotary Spool Holders 2,500 – 4,000 Internal spring tension loss, clip breakage Inspect and clean when swapping spools.
Mechanical Assemblies Mechanical Assemblies Mechanical Assemblies Mechanical Assemblies
Feeder Assembly Internal Gears 2,500 – 4,000 Teeth flattening, gear slipping Clean every 5 spools (2 spools for CF).
Filament Hub (Top of toolhead) 3,000 – 4,000 Multi-inlet wear, spring-latch failure Clean out filament dust regularly.
Feeder Motors (Stepper) 6,000+ Electrical winding failure, bearing lock Run diagnostic if it drops steps.
Electronics & Sensors Electronics & Sensors Electronics & Sensors Electronics & Sensors
Odometer Roller / Hall Sensors 3,000 – 5,000 Magnetic misalignment, dust blocking sensor Clean internal assembly paths.
Internal Mainboard / Hub Board 8,000+ Communication drops, port strain Ensure 6-pin cable is completely seated.
Bambu almost certainly has, but far as I’m aware, does not publish any data on field reliability. That’s the kind of data companies don’t share unless they have a specific reason to share it. But it’s part of the standard process for managing warranty costs.
And, as one of the things I do for a living is deal with product quality and reliability, I have to question those MTBF numbers above. To compute the reliability of a device, you need two things - the time to failure of the devices that fail, and the total number of accumulated hours of operation for the population that has not failed (well, and a couple of other things, too, like “duty cycle”, the hours on vs. off per year). MTBF is not simply the average of how long something ran before someone saw it fail, which is basically what I think those numbers are.
MTBF is a “population statistic”. It can’t be derived from or applied to a single “instance”. By way of an over simplified example, A device with a 1 million hour MTBF does not mean if you buy one you can expect it to run for 1 million hours. A 1M hour MTBF tells you, for example, that if you buy a population of 1000 devices, they can be expected to operate for 1000 hours (1000 * 1000 = 1M) before experiencing a failure. It also tells you that a population of 2000 devices can be expected to run for 500 hours before experiencing a failure. Or 500 devices will go 2000 hours.
Picking one example from the table, XY Belts @ 5000 hours… a 5000 hour MTBF equates to around an 83% annualized failure rate. Meaning, if the belt lifetime was 5000 hours, 83% would fail in the first 8760 hours (the number of hours per year) of operation. For the population of printers that are run 24/7, they would see 83% fail per year. That’s an exceptionally high failure rate. Which is why I am dubious of the data.
You can’t do MTBF without a denominator (the population hours accumulated in the field for units that have not failed) and BBL doesn’t make that data available. So these numbers, whatever they are, are probably not MTBF.
I’d love to see the internal data on that X carraige bearing on the A1. Why dont they just sell that lil cart?
If you’re a hamfisted ogre, that little 4-in-1 hub on the toolhead breaks after ~100 disassembles
I also think certain bits are way more wearable when using the device in certain ways; like you’re going to have worse belt/motor wear at 12 jerk and 20k accel vs 5 jerk and 5k accel. Heatbed and nearby stuff gets baked if running ABS thru it nonstop and cough noone would do that cough. PTFE gets shredded by GF, etc. You go thru lots of nozzles if you crash a lot, that sorta thing.
