Anyone having issues uploading new models?
Looks like after a model is published it immediately disappears or gets deleted even though a confirmation that the model was published successfully shows up in the notifications.
Throughout my first attempt to upload a model, I had to upload it twice, and on the second try it showed up after a minute of refreshing.
Now I’m trying to upload another model and the same glitch is happening. Tried twice with no luck.
Not even getting a warning or error or anything.
Yep, me too. I spent an hour arranging photos and text and it seems to be gone. I’m not looking forward to redoing it. Hopefully it’s just a glitch and will show up soon.
Woot! It showed up after about 5 minutes.
I had the same problem and it reappeared after 5 minutes, however it does not allow you to upload it to contests, that is, it reports that it is participating in the contest, but no actual participation appears
This is an ongoing issue discussed previously.
Same here. i hope that will show up later. i have round about 60 files to import. i stopped after 5 imports. only to show up till now
If you read my link above, you will see there is a way to nudge it along sometimes.
  • Look at system messages
  • Click the link of your published model
  • Go back to uploaded models
More than 50% of the time it will now be visible without further delays.
Yes, here too, it just happened to me, well…
Anyway, I published the same model twice, and in both cases, the system tells me it has been approved, but instead, it gets deleted. :face_with_diagonal_mouth:
Do you mean deleted or do you mean it disappears?
If you click on the link I suggested above and you get a 404 message, that doesn’t mean it has been removed, it means it is a file not found.
After an annoying amount of time, it will show up.
If you create more than one, you will end up with more than one when they eventually appear.
It appeared after half an hour…
For anyone who didn’t read down to the bottom of the link I provided above, here is a direct link pointing out it is now a known issue and is due for a fix in the next update.
Ironically, we need to be patient.
Yes, I know, it is annoying as we are required to wait for the upload and the fix. At least you know it will turn up.
If only someone had mentioned it would…
