I have used Bambu’s wiki to manually adjust the settings as well as using the test profile to no avail. I tried to just print the support interface but despite 0 distance it causes a lot of stringing with clogging up the nozzel.
I think tried to print the whole support as PETG using Bambu’s test model settings from that wiki and that’s even worse.
Anyone had good luck with printing PLA and PETG as support interface yet ? Ironically I published models for those scenarios on the X1C and they work brilliantly on P1S and X1C - just not H2D …
I have tried the other way. IE: PLA as support for PETG.
As long as the supports were on the build plate, everything worked fine. However, when supports were needed on the PETG part itself, it was a no-go.
It is probably an ID-10-T error, but I gave up after many fails!
I print often with PETG as support material for PLA, no problem so far every print came out perfect. I use a shortcut, I select “Support for PLA” as interface layer so the settings get auto-adjusted (z height, interface pattern etc) then swap to PETG for interface layer.
On my X1C, PETG for PLA, yes. PLA for PETG, not so much. PETG printing requires higher temperatures. The PLA tends to jam the extruder because of it. But ultimately, I stopped doing this. I make a lot of functional parts. Unless the purge volumes are VERY high (like in the 1200+ range), some amount of support material remains and contaminates the print, severely weakening the layer-to-layer adhesion and making the prints weak and easy to break.
For a H2D owner, though, it ought to work just fine (provided your H2D works just fine).
I’ve found that the using the HF PETG and PLA has worked really well for support interfaces for each filament respectively. Normal PETG was a nightmare that I never got to work.
