ASA on X1C fails, yet PLA prints are fine, help from the pros needed!
Amazing thank you, I naively didn’t realise drying ASA before use was a requirement, I have clearly been somewhat spoilt by the convenience of PLA to date.
I assumed since the ASA was bran-new moisture wouldn’t be a factor, consider me educated on that score, thanks.
I will give your suggestion a try and dry the filament, silica is on its way and I’ll get a small hygrometer to monitor moisture content in the container (currently the AMS unit). I shall feedback if this works (if the thread stays open) to help others who may come along with a similar issue
