Dear Babulab Team,
I’ve been using an H2D for about a year now (~1,240 printing hours).
The machine runs great so far, but there’s one thing I haven’t been able to figure out, and I’d like your help with it.
I want to print a few lightweight parts made of ASA using a 0.2mm nozzle, but unfortunately, this usually results in under-extrusion, which causes the extruder motor to overload or the hotend to clog. The parts are quite large, so the print time ranges from 15 to 25 hours. The problem always occurs after a few hours of printing, usually around 8 or 10 hours. I suspect that the cold side of the hotend gets too hot, causing the filament to soften before the desired melting zone and get stuck.
Printing temperature is around 275°C, heated bed 90°C, and chamber 50°C. To counteract the filament heating (with some help of the members of this forum), I increased the print speed; the flow rate is now about 3.5 mm³/s. This allowed me to extend the time until under-extrusion to about 8–10 hours. I’ve even managed a 25-hour print this way, but the second print of the identical part stopped again after about half the print time due to a clogged nozzle.
The additional fan on the front of the print head is installed now, but seem to have no positive influence on that matter; I’ve tried various 0.2 mm nozzles, as well as different types of ASA. Unfortunately, without success. Can you please help me?
This problem only occurs with ASA using a 0.2mm nozzle; as soon as the nozzle is 0.4mm or larger, printing this material works without any issues. The cause appears to be a combination of heat (high nozzle temperature, high chamber temperature, high heated bed temperature) and the filament remaining in the print head for an extended period of time due to the small nozzle.
I’ve read that the H2D has a built-in compressor that blows dust away from the laser. Couldn’t you use this compressor to supply cooler air through a hose to cool the hotends? In my opinion, that would be more effective than this additional fan; the ambient temperature up in the chamber near the nozzle and the heated bed is likely much higher than the set chamber temperature and therefore cools less effectively than “cool” air from outside.
I would really appreciate some feedback. Thank you very much.
best regards
