Sure, so what I do is remove the RFID tag from the spool close to depletion, so when reloading to the AMS I need to tell the AMS what type of spool was loaded (manually) , this is when I set it up with the same color as the spool I want to continue the print with.
This allows the AMS to see them both as options to do the Auto Refill. Make sure you select the ‘low spool’ for your print and the other spool refill as Auto.
Cheers.
