I have 10 printers in a small farm. It would be great for Bambu Connect to have a synchronize feature.
For example, you would assign a folder on your computer where Bambu Connect is installed. It would read all of the pre plate slices files of extension gcode.3mf in the folder. You would them, tell it which files you want synchronize with which printer onboard SD storage card.
It would then, re-synch when it sees any changes made to any of the files in that assigned folder. Imagine all of your on-board SD cards, always synchronized with your latest files. You can go to any printer, and select the pre sliced file and know it’s the last version of that file and that it was formatted for that printer.
You probably have your files on other separate folders by design, if this existed, I would simply used a software like Goodsync, to gather files from the working directory and copy them to the connect sync directory, where they would be automatically synced to ALL the printers that Bambu Connect sees.
Lastly, by using bambu handy, you would know the files on your printers storage are the last file version and you would with confidence be able to remotely send the print job.
It would be awesome if this existed.
