B Motor mount purchase?
Hi all. My 2nd X1C started having issues at about 6000 hours…“ressonant freq” errors for the belt tensioner. Kept adjusting the belts, but it never “took” and kept throwing errors. I ordered replacement idler pullys. Successfully replace the top one, then I started on the bottom one (the right side when looking at it from the back)…found the cause. The housing area for the motor and where the threadded inserts are had broken and there were plastic shards in there. Took a bit to get the pully out. I didn’t see the replacement part on line that looks like it holds the motor and the belt tensioner assembly. I had to pry the inserts out to get the idler assembly out. https://imgur.com/a/x1c-goner-T9wUrMU
Bambu Support: Can I buy this B Motor mount part and does this also hold the belt tensioner assembly? Live chat is only the chatbot.
@SupportAssistant
Can you help in pointing to the right person / direction if a part is not listed in shop.
Is it only by raising a support ticket ?
Yes
232323232323232323232323
Thanks for the info…I’ll open a ticket
Can’t buy just the motor mount…have to buy the “XY Motion system” for $150 USD. A weekend project and less than a new printer!
