hi all,
I have a A1, after 10 times 3hours printings this morning the machine started to make a strange noise even when idle and would not take filament. Then it gave the attached error code. Then when I checked it, I saw that the extruder motor could not pull filament and it was strangely forced. I checked the hot end and impellers, no blockage etc. the problem is extruder motor itself even its naked it has weird noise and not rotating just like vibrating.
i have checked
- ams lite connections,
-extruder cables, - usb c cables and all cables
- removed all gears, changed hot end nut naked motor still has problem
İ need help
Thanks in advance
the video links that will last 2 days ![]()
